Page 113 of 126 FirstFirst ... 1363103108109110111112113114115116117118123 ... LastLast
Results 1,681 to 1,695 of 1880
  1. #1681
    Apr 2011
    Tbilisi
    Hello. I used the soft "Jugar-Toyota Smart Key" to write a key for toyota aqua 2012. The ignition is on but the engine does not turn on. What's the error and do you know if this the program can do this model ?
  2. #1682
    wembleyhill's Avatar
    Feb 2009
    Quote Originally Posted by Tariel View Post
    original reset pass in pm
    use buttons
  3. The Following 2 Users Say Thank You to wembleyhill For This Useful Post:
    antonypaul (21st March, 2024), Tariel (6th September, 2020)
  4. #1683
    Who has the means to calculate the new toyota seed numbers or passcode, as we re aware that it is no more 96 digits for the latest cars... i have 2019 rav and need to calculate the passcode to enable all key lost done, help me for fee
  5. #1684
    ibratex's Avatar
    Jul 2015
    angola
    hello how are you . i need reset dumps from rav4 please
  6. #1685
    Feb 2009
    Quote Originally Posted by ibratex View Post
    your files reset pass in pm
    use buttons
  7. The Following User Says Thank You to wembleyhill For This Useful Post:
    ibratex (13th July, 2020)
  8. #1686
    Jul 2020
    I have same problem with Toyota Land cruiser and I am trying to download virgin files for ID smart 89990 60141 but noway if someone can help and send it to me I will be appreciated
    Watts +201120010026
  9. #1687
    Feb 2009
    Quote Originally Posted by yahia20 View Post
    Watts +201120010026
    upload your original files
    use buttons
  10. #1688
    Jul 2020
    How can I download attached file please
  11. #1689
    Jul 2020
    The car came to me with no ID smsrt
  12. #1690
    Feb 2009
    read your original idbox and smartbox upload files and someone will reset them for you
    use buttons
  13. #1691
    Jul 2020
    Thanks I'll make
  14. #1692
    ibratex's Avatar
    Jul 2015
    angola
    hello , i have toyota yaris car without idbox the smartey unit and ecu was stolen , now i got another smartey unit and used ecu and i read dump from used donor smartkey and used donor ecu and car original steering lock
    smartkey donor 93c86
    ecu donor ...epromless????
    steerink lock ori 93c46
    please i need a hand synch or reset please thanks
  15. #1693
    ibratex's Avatar
    Jul 2015
    angola
    solved thanks
  16. #1694
    Jul 2020
    I am trying to register used Smart Keys to 2005 Toyota Prius (gen 2). Have programmed the 93C76 inside the Smart Key ECU (39990-47020) with the file provided by user Brayn. TechStream now shows that there are no keys registered but I am not able to register any Smart Keys using TechStream.
    Maybe my process is wrong or the dump file is wrong? It seem like it should work.
    I've attached the original dump, and the file from Brayn that I'm trying to make work.
    Any help would be appreciated.
    Thank you.
    2005Prius_SKS_Original.zip
    Toyota Smart Ecu Virgin S2943 (93C76 ) from Brayn.zip
  17. #1695
    Jul 2015
    Quote Originally Posted by forumoto View Post
    I have the same problem few years back, but finally gotten solutions, have been doing lost key and spare on Toyota America and Canada specs till 2021, but Europe can only add key. The problem is it cost some $$$$ before service.
    Wish you best of luck.
    Always show appreciation to ur helper NO + THANKS = NO HELP
