Page 116 of 125 FirstFirst ... 1666106111112113114115116117118119120121 ... LastLast
Results 1,726 to 1,740 of 1871
  1. #1726
    Dec 2019
    Quote Originally Posted by trinicolin View Post
    You may have to look down the line of a bad steering lock. Do a diagnostic scan.
    Sent from my SM-G930F using Tapatalk
    I virginized id box, now ignition is always on, tried to match ID CodeBox and Steering Lock got successful message but nothing changed, cant turn off ignition, cant start, no dtc codes
  2. #1727
    Apr 2014
    Quote Originally Posted by Lancolm View Post
    I would go with another steering lock.
  3. #1728
    Dec 2018
    Check the dtc in BCM.
  4. #1729
    May 2016
    このキーのロックを解除する方法
    Does anyone know It cannot be added unless the vehicle's ECU is initialized.
  5. #1730
    hello please reset idbox 93c56 ant smartkeu ecu 83c86 to virgin .Thanks for help
  6. #1731
    koziolek's Avatar
    Under the car
    anyone can help me for adding a key on this file ?
    2010 Toyota Prius
    eeprom 93c86
  7. #1732
    koziolek's Avatar
    Under the car
    no one can help
  8. #1733
    Apr 2020
    how to do this proximity part
  9. #1734
    bram380's Avatar
    Indonesia +628153111774
    Quote Originally Posted by koziolek View Post
    2010 Toyota Prius
    eeprom 93c86
    the key is already stored in the dump
  10. #1735
    koziolek's Avatar
    Under the car
    teachstream showing no key much
  11. #1736
    Sep 2018
    Pakistan
    Hello
    I need help
    I want file for this box
    In eeprom no file. Any one have virgin file plz share with me
    Thank you
    89990-12290
  12. #1737
    Jan 2014
    morocco
    Default plz help here
    hi all
    i have a problem with a toyota rav4 2008 keyless. the car came to the garage with keless system not working its start only when u put the key near the start botton, so i trien to reprograme the key with avdi abrites i follow the procedure but its stops when the progrqme ask to put the key in the seat .
    the car is totally dead no ignition
    atached all files
    immo box 93c46+ smart box 93c86
  13. #1738
    Jan 2021
    Thanks alot my friend
  14. #1739
    Dec 2018
    Quote Originally Posted by NiZaTroniC View Post
    hi all
    atached all files
    Check door receiver controller and its harness three wires to smart ecu and one ground. located possibly at rear pillar.
  15. #1740
    Oct 2015
    Please tell me what i need to write into smartkey. Car is Lexus is220d. Dump is from smart key box 93c86.
