Page 119 of 126 FirstFirst ... 1969109114115116117118119120121122123124 ... LastLast
Results 1,771 to 1,785 of 1880
  1. #1771
    Oct 2015
    Where are your files? What u need exactly?
    Quote Originally Posted by Eyasu View Post
    Hi can some one helpe me toyota prado 2015 smart box 93c86 and id box 93c46 virgin file
    No Thanks, No Report = No HELP
  2. The Following User Says Thank You to usman4 For This Useful Post:
    Eyasu (15th June, 2021)
  3. #1772
    Dec 2018
    Quote Originally Posted by usman4 View Post
    This is may file
  4. #1773
    Dec 2018
    I want you to virgin for me thanks
  5. #1774
    DK Veteran buga37's Avatar
    USA
    I need help resetting both ID/IMMO BOX
    Lexus IS300 2018, 89784-53040,89990-53381
  6. #1775
    ray-ray's Avatar
    I have a 2008 Camry hybrid with issue Proxy 1 is the correct system with AAB 0140 board.(lost key) but near by because the car detect it and stepping on the brake make the button turn green. Reset start under the only system it recognizes (proxy 3 same as proxy 5 2017 up) car has been reset but won’t register even the lost proxy that was found after the reset. Tis say smart ecu has a error here is the read and the original proxy in the system.
  7. #1776
    Aug 2011
    GB
    Hello friends,
    For a Land cruiser GRJ200L of year 2012 I need ORI Dump to virgin:
    - ECM ecu 89661-60R70
    - Smart key ecu 89990-60034 or 89990-60144
    - ID Box ecu 89784-60080
    - Steering Ecu 89181A
    Thks in advance
  8. #1777
    ray-ray's Avatar
    No one is helping on these tread… here is a image of a virgin dump 93c46 (16bitmode).. no password need just look and copy.
  9. The Following User Says Thank You to ray-ray For This Useful Post:
    urcarpc (6th April, 2023)
  10. #1778
    May 2016
    Hello.
    How can I enable the smart function after writing the smart key information to the smart ECU?
    You can lock and unlock the door with the button of the smart key.
  11. #1779
    May 2016
    [QUOTE = ray-ray; 4166499]問題のある2008Camryハイブリッドがありますプロキシ1はAAB0140ボードを備えた正しいシス テムです(キーを紛失しました)が、車がそれを検出し、ブレーキを踏むとボタンが緑色に変わるため、近くに あります。認識される唯一のシステム(プロキシ3はプロキシ5 2017以降と同じ)でリセットを開始します。車はリセットされましたが、リセット後に見つかった失われた プロキシも登録されません。スマートecuにエラーがあると言うのは、システムの読み取りと元のプロキシで す。[/ QUOTE]
    Hi, it seems like the same problem as me. Initialize and register the ID CODE BOX and smart ECU, or delete all other smart keys and re-register them, leaving all the working smart keys, and it will work normally.
  12. #1780
    Aug 2021
    Default Toyota Smart key GXR 200
    I have all lost Toyota smart key, need help please, already virgin Id ecu code and Smart box , but , i add key , no result , Obdstar start and lonsdor file , i dont know where is problem,
  13. #1781
    Aug 2021
    Toyota Smart key all key lost , toyota land cruiser GRX200 years 2009 , i already virgin id ecu code and smart box , but when i programme key , no result, lonsdor and Obdstar failed
  14. #1782
    Oct 2015
    Quote Originally Posted by Ditrich View Post
    post original dump and key data here.
  15. The Following User Says Thank You to usman4 For This Useful Post:
    duzaven (2nd September, 2021)
  16. #1783
    May 2016
  17. #1784
    Feb 2019
    Nederland
    problem solved. helped me usman4
  18. #1785
    Oct 2021
    can someone pass me the original toyota highlander 2002 dum memory 93c42 millage
    can someone pass me the original 2002 toyota highlander dum
