Hi Tyrone
i have 2009 toyota voxy smart key model,original the car came to dealers not starting.The car could turn on but the start button at no time went to green nor the immo light extinguish at no time. I have a new smart box however it wont take the keys that orginal came with the vechile.i have old keys and the old immo bin file can i send it and you check it. Just want to know if the key data is good and the matching data for the ECU is ok they are sync.
Here is the key data for the 2008 toyota voxy and the key dat will be attach also.
data:94 83 7F4CEA1C
RESP:1FD707- BEC68E
INFO: DST PLUS LLLL
CHIP: 4D SMART CARD
TYPE: 4D 67 CRYP
Can i use the old box? If not how do i get the id virginize. I sent you the orginal dump from the car with key data did you see it i want to use that. I tired to fine that box i could not locate it where the diagram said it should have been i don't see it can a diagnostic tool pull this id code
ok thanks i will pull the dash down and get you the box and the data
Hi Master Gwee
I need your Help
Can i use Toyota Vitz Dump in Toyota Belta.
Somebody already tried to make a key.i recived a car without Eprom in Ecu Id Code.![]()
Could someone help me reset smart key dumps toyota rav4 year 2013 smart box eeprom 93c86, ecu id eeprom 93c56
Attached original dumps and my modified dumps (not tested yet)
best regards
thank you for reply gwee, car started
best regards
Hello Masters PremierD and Gwee just want to let you know that that i wrote pg 1 to 4 for customer on regular key customer was in a rush, have not been able to get customer to bring back car to write the file with new smart key, you guys fixed for me ,, the customer seems to be so happy that car is driving, however want to say thanks and will post results as soon as i can get hold of customer,,thanks,..again
Hello teachers,
please friend Gwen inserts this original key used Toyota smart key:
Toyota Fielder 2011
on the smart key ECU EEPROM 93c66x16.
s93c66.bin 512 B
https://mega.co.nz/#!WAIESC5R!_7kfntgi1z1l9rszSH6zZjjiF_PWjnqOq-43oViuuU8
thank you very much for your kind help.
I try to help while waiting for the master Gwee
