Page 5 of 125 FirstFirst 123456789101555105 ... LastLast
Results 61 to 75 of 1871
  1. #61
    La Paz, Bolivia
    Hi, I found this module only.
    https://mega.co.nz/#F!DNpHUaJK!52fb1sUMS_2beT29DD4nvg
  2. #62
    iamfooser's Avatar
    Sep 2012
    Could you please check if my key data is in the dump? Workshop did some repairing job to this car, and now it could not turn on dash. Car could not recognize smart key, even by contacting the emblem.
    Thank you in advance.
    Regards,
  3. #63
    iamfooser's Avatar
    Sep 2012
    And if I couldn't add back the same key, what should I do next? This car is about 2 hours drive away. Need to prepare before I go over. Thanks
    Sent from my HTC Desire 600 dual sim using Tapatalk
  4. #64
    iamfooser's Avatar
    Sep 2012
    Tried programming a new key, but programmer could not communicate. Attached is the ID code dump. Please let me know if there is anything wrong with it.
    I noticed a few things on the car.
    1. When I press the start/stop button, there is no reaction at all. No amber light or reaction on dash or the button.
    2. When I press the door handle smart button with the original key around, there are some beeping sound. But when the key is not nearby, there is no reaction at all.
    3. Dash immo light kept blinking no matter what.
    The initial problem with this car is that, the aircond leaked and soaked the wires on the passenger side. Some of the cable got came off and some of with was covered with minerals. Workshop did their best to join them back (I do not know whether they joined the cables correctly or not).
    Could it be the immobilizer amplifier got short circuit? And is it plug and play for the amplifier or I need to do some coding?
    Thank you for your time and input on this.
  5. #65
    iamfooser's Avatar
    Sep 2012
    Could not scan with diagnosis. No communication.
  6. #66
    DK Veteran Carsoft2003's Avatar
    Mar 2011
    Algeria
    Default Lost key prado 2010
    Hi Mr Gwee you have add for me key for my Prado with lost , I have send you key data with smart key virgin 98 , the car start
    ok before the start button.when I try to add this virgin key no ok I test with zed full , T code and X100 but no ok
    now I have used key , with key data 94 and I need to add it.
    Thanks an advance
  7. #67
    Mar 2011
    Algeria
    please gwee I need your help
  8. #68
    May 2011
    Hello
    I have big problam but my english not so good try to anderstend .Itry to make key to land cruiser 200 2008 i try to read id code and i lost the dump
    Naw i have dump from smart box and a new key the id cod no89784-60010 the smart boxno is89990-60050
    Transponder recognized as Texas Crypto
    ID 6D - 67/68/70 - JMA TP xx
    Password: D4 - Locked
    Identifier: F0 - Locked
    Serial number: CE1C8A2A - Locked
    Secret key: Locked
    Toyota/Lexus smart key
    this is the key
    thank you
  9. The Following User Says Thank You to asheri For This Useful Post:
    kyawkyaw (17th October, 2015)
  10. #69
    Quote Originally Posted by Carsoft2003 View Post
    You should have to be added smart key with Page:1 98 not 94
  11. The Following User Says Thank You to ngakson2002 For This Useful Post:
    Carsoft2003 (10th June, 2014)
  12. #70
    Mar 2011
    Algeria
    Thanks friend , but I try to add the virgin key with P1 98 but no ok I have try with zed-full avdi X100 t300 and no ok
    please check for me if the key is virgin or not !
  13. #71
    iamfooser's Avatar
    Sep 2012
    If you cannot add the key then your key is not virgin. Program with a virgin key and it will definitely work. Had same issue before.
  14. #72
    Mar 2011
    Algeria
    I buy it from turky !
  15. #73
    iamfooser's Avatar
    Sep 2012
    You don't have a choice now my friend. Keep that key and use it for all lost next time. I always use that same key for our master to add key to dump and program a new virgin key with programmer later.
    Or try to claim the key from your dealer.
  16. #74
    May 2011
    Hello
    sameone can help?
  17. #75
    May 2011
    Hello
    I have tmpro i can send the screenID 6D - 67/68/70 - JMA TP xx
    Secret key: Locked
    Thank you any way
