Hi need a smart access reset without ID box.
here you go. reset ok try and report
pass pm
LooserX (25th May, 2017)
I have tried resetting this unit using Abritus and it seems it cant reset it,it says dump is either damaged or unknown,if i make master key the car does not recognize the key either.,it says key not detected even touching the start button with the key still nothing happens.
Landcruiser 2013 smartkey immo box reset
Somebody please help to reset the immo-box 89784-60030 on a 2013 Landcruiser with smart key and 93c46 serial eeprom
Love this forum
hello guys I got hilux 2.5 g chip ecu and immobox damage I found used ecu not match with immobox and need add my key can any one here give procedure?thank u
Hi Members
i got a Car Toyota Mark X but ID Code is Missing.
and body have a Dump for mark x Chasis NUmber GRX120
ID Code
Part Number 89784-22010.
I need a Dump Only.
here guys
IS THIS YOU NEED THE MASTER?Immobilizer Innova,fortuner,hilux.rar
pm If this correct
huga46 (12th May, 2017)
Hello all members
I have a Toyota Premio 2008
ECU not connection by OBDII
Smart key system...
Any solution... not start the car, the smart Box and ID Box is ok...
Pleads
Enviado desde mi iPhone utilizando Tapatalk![]()
i guess there is no Ign ON .. and you working at off ign or there are no power in the OBD2 port ? if yes you need to make an ign ON from the ER fuse box (EFI relay) if there is still no comm. with the ECU you need to check the CAN bus from the OBD to the ECU .. if ok go directly to junctions or wiring joints close from your legs in driver side or passenger side .. as well as you have to check the security LED .. if still ON or OFF (faulty ID code box) if flashing ignore the ID code box and go to the other mentioned options .. hope that will help ..
Slem
