Page 86 of 125 FirstFirst ... 3676818283848586878889909196 ... LastLast
Results 1,276 to 1,290 of 1872
  1. #1276
    Hello Yes Still I have a problem with Car , Swich can Turn ON but Car cant start and there is no move in steering lock car have 2 smart keys and remote control works perfect security light flashes in smart key actual data steering lock and unlock status says Unknown , and B2786 No Response From Steering Lock ECU , is in smart key system. I need wiring diagram for checking
  2. #1277
    Nov 2016
    Default ***Toyota Smart Lost Key Solution - No Id code needed***
    Quote Originally Posted by Saman View Post
    Read the eeprom and post here
    Enviado desde mi iPhone utilizando Tapatalk
  3. #1278
    its EEporom file of Steering Lock ECU
  4. #1279
    Nov 2016
    hello friend
    reload and synchro
    press thanks and reputation = pass in pm
  5. The Following 3 Users Say Thank You to UliZam For This Useful Post:
    Brayn (29th May, 2017), MartinMG (8th January, 2020), ukimack (20th October, 2022)
  6. #1280
    Brayn's Avatar
    Oct 2015
    Colombo
    Quote Originally Posted by UliZam View Post
    hello friend
    reload and synchro
    good. thank you
    but when we reset smart ecu and id code box no need to reset ST lock. it will Auto learn
  7. The Following User Says Thank You to Brayn For This Useful Post:
    Tagne (31st May, 2017)
  8. #1281
    I am sorry Customer moves the car to dealer thank you so much friend for all your help I appreciate your help
  9. #1282
    Apr 2014
    Dear DK member
    Please help me to add new key to smartkey yaris 2015
    Key Yaris 2015 Project.zip. Situation is all key lost.
    thank you
  10. #1283
    edit
    removed
  11. #1284
    Apr 2017
    Quote Originally Posted by sadarmeng View Post
    Dear DK member
    thank you
    You may need a key programming tool
  12. #1285
    Aug 2010
    Hi guys, need help with this toyota allion with smart key system. All keys lost and can't get to reset ECU through OBD2, tried using obdstar x100 pro, t300, and techstream with no luck. So removed the dash and got out the immo ecu and smart key ecu, read both files and attached them here. If I get the dump reset and loaded back, will I be able to code a new key by obd2?
  13. #1286
    May 2016
    Hello
    I have skp900.
    Can you carry out this activity?
    https://www.key-programmer.com/2016/...star-x100-pro/
    What kind of data should I write in 93C86?
    Or do I not need to write anything?
  14. #1287
    vanos batam's Avatar
    Batam-Indonesia
    Quote Originally Posted by znakedwrx View Post
    Hi guys,
    I have 2015 Toyota Vellfire 3.5 with no keys.
    Vin: GGH30-0006494
    Smart key box: 89990-58200
    Attachment 346408Attachment 346409
    I have removed 93c66 from the board and here is the dump file
    Attachment 346410
    2nd readout with wellon
    Attachment 346418
    Can anyone help me out with this baby ?
    hi..
    C86 inside ??
    or your C66 ??
  15. #1288
    Apr 2014
    Quote Originally Posted by vanos batam View Post
    hi..
    C86 inside ??
    or your C66 ??
    For This Smart key box: 89990-58200
    Use Small TSSOP with C66 Mask mister
  16. The Following 2 Users Say Thank You to sadarmeng For This Useful Post:
    ucokseparoh (13th June, 2017), UliZam (19th July, 2017)
  17. #1289
    Batam-Indonesia
    Is there no key data in that eep.
    But it solved by kline.
  18. #1290
    Mar 2016
    Dear DK member
    thank you
    No tool can program all key lost. you need buy new smart box+ steering lock replace
