Page 96 of 126 FirstFirst ... 4686919293949596979899100101106 ... LastLast
Results 1,426 to 1,440 of 1880
  1. #1426
    Default Corolla 2014
    Somebody can help me? I need to program a key for this car, i try witch techstream, x300, skp900 and nothing, i have read steering, smart and id code
  2. #1427
    Jul 2016
    pls i need help to reset data for 4runner 2017 smart box 89990-35020 and id box 89784-35020 attached the c86 from smart key box and c56 from immo
    thanks in advance
  3. #1428
    metalik's Avatar
    Mar 2012
    Quote Originally Posted by cyril View Post
    thanks in advance
    Try this one.
  4. The Following User Says Thank You to metalik For This Useful Post:
    cyril (12th April, 2018)
  5. #1429
    Jul 2016
    thanks worked directly
  6. #1430
    Jul 2015
    Hey friend,
    You got a corrupt dumps, please check carefully.
    Quote Originally Posted by madjid78 View Post
    Higlander 2014 after a small accident and a bad battery does not see the keys. On the panel the text "key is not recognized" and does not respond to the buttons. The Steringlock is open and does not close. In the diagnosis, S CODE CHECK have NG.
    Please help me or kick me in the right direction.
    Sorry for bad english.
    Always show appreciation to ur helper NO + THANKS = NO HELP
  7. #1431
    Oct 2011
    Petropavlovsk.KZ
    Hi ! Please help me solved problem. Have car Prado 2017. Lost all key (fired in flat...)
    Smart key ecu 89990-60430 inside ssop 93c66. ID code ecu 89784-60160 not have inside eeprom,
    Smart key Page1=A8 . Dealer tell need change smart key ecu and id code ecu.
    Possible write manually key or emulator to eeprom 93c66 in smart key ecu, or buy virgin id code ecu and reset smart key ecu ?
  8. #1432
    Mr_Fix's Avatar
    No keys in 93C66. They iside MCU D-Flash.
    Try use Tango + Toyota by OBD.
  9. The Following User Says Thank You to Mr_Fix For This Useful Post:
    CPI (2nd May, 2018)
  10. #1433
    Mar 2015
    Default 2015 highlander smart key
    can any one help me add key data or reset smart data for this 2015 highlander smart key 93c66
  11. #1434
    Oct 2011
    Petropavlovsk.KZ
    Quote Originally Posted by Mr_Fix View Post
    Thanks! Im tried Tango + V6.6 with use PassThru device - OpenPort. Not read data from this smart key ecu (unkown)
  12. #1435
    Jun 2016
    world
    Quote Originally Posted by CPI View Post
    You Can just try to read with fly terminator and program emu with Tango without problem. Tester on Lexus is250 year 2017.
    Thks.
    Envoyé de mon Armor_2 en utilisant Tapatalk
  13. #1436
    rob h's Avatar
    May 2011
    How did you read this,
    Off board, possible 16bit ?
    Quote Originally Posted by immoresearch View Post
  14. #1437
    Aug 2016
    GB
    hi i was reset your file ready to program by diagnostic , but i dont know how to post file .
    i am also make some virgin file all post here
  15. The Following User Says Thank You to autocar88 For This Useful Post:
    trinicolin (7th December, 2018)
  16. #1438
    Jul 2016
    hello friends pls i need help to resert smart key c86 data for rav4 2011
  17. #1439
    Jul 2016
    transfer the file to rar and them pusk go advanced button u will see the attach photo
  18. #1440
    Mar 2017
    new kind smart key module ,93C66 or no 8 pin eeprom,lost all key,how to reset or programming new key.Thanks
