Page 35 of 126 FirstFirst ... 2530313233343536373839404585 ... LastLast
Results 511 to 525 of 1880
  1. #511
    hamzadaw2000's Avatar
    Aug 2013
    Quote Originally Posted by gwee View Post
    fail to add or fail to start?
    post pg 1 of your key / frequency and also pic
    post your smart reset dump also
    please find attached, for frequency it is american system as car imported from USA, key black color with panic .
  2. #512
    Aug 2013
    Quote Originally Posted by hamzadaw2000 View Post
    Hello.
    i did not find an ID-box of this car, location unknowns or has no id-box? I attached Smart dump with key page please assist me to start.
    Best regards
    Mr. Gwee please find smart dump in my first post.
  3. #513
    Aug 2013
    Default Versa 2013
    I write again both ESL (land cruiser esl dump) and smart dumps, i add key successfully, ignition on, remote function ok, steering still locked, engine not running and security lamp still
  4. #514
    Aug 2013
    Car started fine, thanks for help
  5. #515
    Moderator
    PremierD's Avatar
    Jun 2009
    OK .. what did you forget to do .. or do wrong that caused it not to start then
  6. The Following 3 Users Say Thank You to PremierD For This Useful Post:
    antonypaul (26th June, 2015), hamzadaw2000 (18th June, 2015), mvtamele (29th June, 2015)
  7. #516
    Aug 2013
    he must have used land cruiser id code, esl, smart, ecu and also engine
    I used your smart rest dump, only Esl I tried to put land cruiser id box version and engine started
  8. #517
    ttzag's Avatar
    Jun 2010
    digital-kaos
    Gwee is a great man
    He stay with me step by step till end .
    The problem was the key is used and now same key is work , start and smart function .
    About member( large) dump i tested it , car start but somthing wrong cuz when i tried to add key communication failed even no beep.
    And especial thank to cj.
    sent from LG-G2
    Actions speak louder than words
  9. The Following 7 Users Say Thank You to ttzag For This Useful Post:
    antonypaul (26th June, 2015), cjawahir (21st June, 2015), gwee (20th June, 2015), hamzadaw2000 (20th June, 2015), labase (30th June, 2015), mvtamele (29th June, 2015), PremierD (20th June, 2015)
  10. #518
    Aug 2013
    Thanks Gwee for great threat with great support
  11. #519
    Mar 2012
    here
    Quote Originally Posted by labase View Post
    hi MATE,
    Please i need help with smart key for toyota land cruiser. all keys lost.
    i have a key which i want to learn.
    page 1: 98
    page 2: 28
    page 3: EE21322A
    page 8: 982433CA73
    many thanks, hopefully someone can help!
    thankfully,
    labase.
    Hi dears,
    please it is possible to start the car with another id code? the car is very far and the client has misplaced the original code id.
    we had ordered with another id outgoing code of another car.
    tks
  12. #520
    Mar 2012
    here
    of course u can
    Hi dears,
    please i need reset to program on car, i precise that i oder id code so ecu agregation is for the car.
    thks
  13. #521
    Mar 2012
    here
    just write this file and add key
    after car started and stopped, sync for 30 mins with ignition on
    thks i'll do job and post result.
    thks.
  14. #522
    topclef's Avatar
    Mar 2010
    Hello all ,
    please, Can someone help me to add key for Toyota prius 2011 lost all keys ..
    smart key data
    P1 / 98
    P2 / E5
    P3 / 2B 2B BE 1D
    P8 / 98 24 26 44 DC
    thank you in advance
    you have two choices in the morning: go back to bed and continue dreaming, or you get up to make your dreams come true
  15. #523
    Aug 2013
    Default ***Toyota Smart Lost Key Solution - No Id code needed***
    Thanks Mr. Gwee
  16. #524
    Mar 2012
    here
    Hi Gwee,
    please i try just try today to do job but not work. contact not open , please can you help me ?
    thks.
  17. #525
    Mar 2012
    here
    where is the post??
    Please it is post 764 and 765.
    Tks.
