i can any one help reset this immo box 89990-52260.
here's your reset
thank you usman4 worked first time
regards
anytime.. and by the way its smart not immo![]()
Jobeso66 (3rd December, 2018)
usman4 please could you do this one for me Smart key!!
regards
here u go.........
simon77 (11th April, 2016)
Hello Anyone help me for renualt fleuance 2011 odo Correction Data lines..
Jhone mate..please introduce yourself first here : Introduce Yourself
hie guys i have a toyota auris, the immo box was stolen and i want to replace it with another one so I'm looking for help on hound match it with the computer box and the key
Could you post your dump here i will virgin it for you. or try this method try and perform syncronize between the ECU and IMMO open driver's door, turn ignition ON short terminals Tc (PIN13) CG(PIN5)in the DLC/OBDII connector leave it for 45minutes the car should start
Jobeso66 (3rd December, 2018), LEORNARD NKATA (11th April, 2016)
ok thanks so much will try during day time tomorrow and i will report back thanks so much.
You are very welcome
Hello M8,
I have highlander 2008 all key lost i noticed the vehicle did not have receiver it will be very difficult to reset through obd because if i do so, i would beable to program key to the car, i will be glad if anyone can help me add up used key to dump, smart details 89990-48020 232500-2771, I will add the dump as soon as i remove the Smart Key and post keydata
Regards
Hello M8,
Here is the dump please help to add key to dump
Regards
