Hi. Can anybody provide me with virgin files for this 2010 tarago smart box and id code box please:
ID code box: 89784-28011
Smart ecu: 89990-28133
can you help me with virgin file ?
Smart key Valeo 89990-0D020
Id Code box 89784-0D030
Many thanks
Hi!
Lost all keys to a Toyota RAV4 2011. Need virgin dump for "Aggregation ECU" 89300-42081 which contains EEPROM 93c86.
Original dump attached.
Thanks.
Hi there any one can help me I have problem with all key lost situation
Toyota land cruiser prado 2015 and I want vergin file for smart box and id box
Please help to reset id box 89784-02020 and steering lock
The modules are from another car.
Thanks.
dear mates
i have toyota corolla 2017 with id box code 89784-02080 american species car has key but remote only works engine not crank elv has missing power from smart ecu need please virgin file dump for id code box to gain the communication between the system eeprom 93c56 data size 256bytes please if any one can help me will be much appreciated
best regards
NO ADVERTISING PLEASE
Hi need reset smart key ecu 89990-52260
Ive added key with fvdi but it doesnt work
Toyota vitz nsp130 2011
[EDIT]
solved it
Hit like and thanks if I've helped you!!![]()
Hello,
I have 2019 Toyota Tacoma all keys lost. Can some one help me with the procedure of making new key to start the car.
hi, guys i have a 2008 toyota previa with smart key dont star ecu is denso there are inmo off to this problem
Hi friends
lost Toyota Vits 2008 smart key,I have
Used key (secondhand),I read dump from
ECU agregation 89300-52120, please add
Key to the dump,
Pg1=98
Pg2=64
Pg3=37D4462A
1.ECU 89661-52M60
2.ECU agregation 89300-52120 smart
ECUIC: 93C86 or IC: 93C66
3.small ECU ID code 89784-5201
Regards
Hi mates
Happy weekend
Please help me
PG1 = D4
PG2 = 86
PG3 = 5F 93 E4 2A
PG8 = D4 24 12 E7 31
NEED TO WRITE THIS KEY TO ECU AGREGATION TOYOTA YARIS 2008
DUMP ITS WITHOUT KEY
Hi mates
Toyota Yaris 2008
VIN:KSP90-5208319
I have read both eeprom from
1,ID code box(89784-5201 )93C46
2.smart ecu(89300-52120)93C66
could you please help me make me rest dump,
to get Ignition on, to add key via diagnostics tool
I really appreciate your help
Thank you
Regards
hussin (6th June, 2023)
