Page 104 of 125 FirstFirst ... 4549499100101102103104105106107108109114 ... LastLast
Results 1,546 to 1,560 of 1871
  1. #1546
    ibratex's Avatar
    Jul 2015
    angola
    hello mates i have a problem here , i need reset these two dumps from lexus 570 JTJHY00W0F4179705 03/2015 middle east
    car came to shop with all key lost situation now i make key with tango i have ignition but no crank and immo flash light blink i tried with tango dump editor to check sync says synch code error so i synched now car crank but no start , i tried 45 min procedure maybe also synch ecu but still nno hope always crank no start but no more immo light ... now please i doubt that smartkey unit dump is corrupted somehow
    smart number :89990-60304 ibox number : 89784-60090 THANKS in advance
  2. #1547
    Apr 2014
    Quote Originally Posted by ibratex View Post
    Are there any DTC on the ECU?
    Sent from my SM-G930F using Tapatalk
  3. #1548
    ibratex's Avatar
    Jul 2015
    angola
    no dtc
    Sent from my SM-G950F using Tapatalk
  4. #1549
    Apr 2014
    no dtc
    Check for spark, fuel and injector pulse.
  5. #1550
    ibratex's Avatar
    Jul 2015
    angola
    you confirme that files are ok ?
  6. #1551
    Sep 2015
    No dtc and no immo light? The car cranks. Check mechanical problem. It be the fuel pump. And also try to sync id code with ecu with tango. And then use techstream to sync id code and steering lock by ovd on smart key special function. I had a situation like that. And it was the sync between steering lock and id code. Used tango to sync but still problem was there. And then i used techstream to sync by obd and the car started fine. Obdstar tools also sync id code and steering lock by obd
  7. #1552
    Aug 2018
    I have a 2001 Toyota Celsior - all master keys lost. I tried to reset the smart ecu but I cannot.
    Are there any businesses that will reset a smart ecu?
  8. #1553
    Jul 2010
    pls i need help to reset data for tacoma 2016 89990-04020
  9. #1554
    Oct 2017
    i got parado 2018 AKL with smartkey box 89990-60430its new type smart box.so all programmers fails to pull data.aslo cant read by eeprom as it is not supported yet by any device .
    So someone told me only option is to buy virgin immo from dealer and program.Now i buy new smart key box from dealer.
    my question is how i can program and synchro with id code box. Need tested answer who have done ..
    Thanks in Advance
  10. #1555
    Feb 2010
    toyota 89990-0d030 with 95160 eprom inside. does any one have a virgin file or can add a new key to file . the smart key is id46
    regards
  11. #1556
    Jan 2019
    2009 Toyota Camry ALL Key Lost
    i need set of file for smart unit ,id box and esl
    car came without keys and someone tempered with the original files
    key type is 94 and i need set of files to make key with Tango
    thanks in advance
  12. #1557
    Jun 2019
    Yokkaichi, Mie, Japan
    Hi..I do have a same year model Toyota Aqua Car. I have some problem to start my car since I have changed ID-Box and Smartkey Control unit. if you solved your problem, would you please share the Aqua virgin dump file with me? M y email is sinkoha@yahoo.com. thank you so much for your help.
  13. #1558
    Jun 2019
  14. #1559
    death9891's Avatar
    Jan 2010
    E.U.
    Toyota Yaris III immo
    Help lose lost keys,
    what is the layout marked in red, what to read with this programmer
    I have to reset the virgin
    Attachment 635320
  15. #1560
    death9891's Avatar
    Jan 2010
    E.U.
    what is the processor ??? 12850 1436KM41L
