Results 1 to 9 of 9
    Sep 2012
    Default Citroen jumpy 2004
    Hello I have to modify a dash and carries a 68HC08AZ32 is possible with xprog.
    citroen jumpy 2004.
    thanks and best regards.
    Sep 2012
    anyone can help me
    Sep 2012
    nobody knows anything about this can make the xprog?
    kumistheru's Avatar
    Aug 2013
    Yes, xprog supports this motorolla MCU, please check page 17 of xprog user manual for connections (User manual can be found under 'DOC' folder of xprog installation directory).
  5. The Following User Says Thank You to kumistheru For This Useful Post:
    arturius (1st May, 2014)
    Sep 2012
    is xprog clone.
    anyone know the pinout of this car thanks
    Oct 2012
    FIAT SCUDO.doc
    Do as in the attached file. Leg of CPU power to be removed from the scheme, there is enough to lift the throttle on the board.
  8. The Following User Says Thank You to spidometr1973 For This Useful Post:
    hackbest (16th March, 2014)
  9. #7
    Sep 2012
    and pinout of the dash I need 2004 citroen jumpy
  10. #8
    Oct 2012
    citroen jumpy = fiat scudo
  11. #9
    Oct 2012
    SecBit 9F-A4-F6-E0-F6-E0-F6-E0
