you need good mod file. whith dpf off and additive off.
ALL TUNING.
THE BEST OR NOTHING. THANKS + REPUTATION .
bythe switch solution doesnt require removign anything.
Anyways never remove the aditive module...it will be worse
Can anyone help with this file?
Car is running ok.What is going to be worse?
after dpf off, put diesel into the additive tank,
Winols,Swiftec,Ecm Titanium, Kess V2, Ktag, Portugal Fg V54, Powergate, Byteshooter, Beeprog...
mastaflex (5th October, 2014)
focus will have level sensor in addative tank,so you have to put diesel in to it.
I disconnected the fuel additive module,and left the additive in tank,all is OK now...
hi,i have same problem,so when you disconect that modul that red light is of now?no limp mode? my car have limp mode,map is 100% good,before never problem,that is first ford with problem like that,i put diesel inside and reset everything with IDS,fault i coming back after 20 second's when i started car.
