Page 1 of 15 12345611 ... LastLast
Results 1 to 15 of 223
Thread: solo2 clone
    DK Veteran eattheliving's Avatar
    Nov 2008
    Default solo2 clone
    Hi All,
    I'm looking to upgrade from my duo to a solo2 but was looking to try a clone for the first time.
    My questions are:
    1: Are they quite a reliable build and quality?
    2: Can I load a vix image dated pre December 13 or is there a newer one which is good?
    3: Can anyone recommend a good supplier and a rough cost?(in pounds please)
    thanks all
    Senior Member shankill2012's Avatar
    ULSTER
    I purchased a solo2 clone in January and its a brilliant machine , 1: Build quality is excellent - internals are spotless, really neat and tidy , everything sturdy as should be. 2: As far as I know any image before 13 December should work BUT - (My clone auto updated by accident in January and installed a post December image with supposed anti clone drivers and it worked fine - which at the time was a mystery to me but it now seems that solo2 v2 clones will take any image new or old and there is also a fix out for solo2 v1 boxes that enables you to update to latest images also - (USB_FPGA_UPDATE ) 3: I purchased from L&W on ALIEX***SS total ?159.25 took around 7 days for delivery by DHL. , At this minute in time I cant fault this clone one bit , everything works as it should - hard drive , usb drive for picons, plugins, epg, The only downfall is the remote controller, it clicks when using and mine is sluggish - sometimes have to press down hard and maybe a couple of times, but all in all im really happy with the box.
  3. The Following User Says Thank You to shankill2012 For This Useful Post:
    pugwas (12th April, 2014)
    Belfast
    I agree with Shankill its a great box ive had mine from nov i done the update on it the other day and its running the new Vix Zeus without problems
    Mick
    Nov 2008
    thanks for the info guy's its very helpful.
    can you use the qwerty remote to browse on these boxes?
    cheers
    Mar 2011
    I've had mine since around the start of Feb, mine was a v1 but I've since updated it to the v2 firmware so it can run the latest drivers. Mine replaced my Duo clone and has been running faultlessly since I got it. It does everything that the Duo did and more, the more bit is that it can PiP with HD channels and it plays all MKVs that I've chucked at it to date including very high bitrate films without any problems.
    Mine cost me around ?155 but I also got stung for ?18 excise duty.
    Nov 2008
    well that's it guy's I've gone and ordered my first clone.
    have gone with L&W which shankhill has used and ordered the solo2.
    can't wait now. will post when I get her up and running.
    Mar 2011
    Her? I think you need to get out more
    DK Veteran lincsat's Avatar
    Jun 2008
    I've been trying a Chinese copy, this one with the X-Chip and not the Ferrari chip and I'm very impressed. It does take the latest un-patched images, tried BH2.0.9 with online upgrade to 2.0.9.1 and OpenViX Zeus 003 with online upgrade to 005. It seems faster than the genuine (although I'm sure it isn't). Very stable, good build quality and considerably cheaper than an original box.
  10. #9
    Nov 2008
    Quote Originally Posted by lincsat View Post
    thanks for the info lincsat. Should it have a sticker on the box itself saying what chip it has?
  11. #10
    ULSTER
    Quote Originally Posted by eattheliving View Post
    Mine had no signs of which chip was inside the box - only when I took the cover off there was a small sticker saying "x chip" on top of the chip.
  12. #11
    Nov 2008
    Quote Originally Posted by shankill2012 View Post
    cheers matey, will look when I put the HDD in.
  13. #12
    Nov 2008
    hi lincsat,
    just popped the hdd in my solo2 and am now ready to re flash to a vix image. It has the blue X on the chip. I'm gonna try zeus 003 but do you think I would need to upgrade the boot loader file first?
    cheers
  14. #13
    Belfast
    hi lincsat,
    cheers
    If its a new box mate t will more than likely already been updated
    Mick
  15. #14
    Nov 2008
    cheers mickmc68. brand new box from china. spose it won't hurt to install it anyway. what do I look for on a blackhole image to tell me. I've never used B/H only vix.
  16. #15
    Nov 2008
    ok guy's here's where the fun starts.
    Formatted my memory stick and put the zeus 003 image on it (original download from WOS). Powered off the box, put in the usb in the front port and started the box back up. Got a message on the front saying "update, press power"
    did that then the box read the mem stick and booted up into the B/H image.
    do you have to do something different to re flash a new image on a clone?
    help please?
    cheers
