Results 1 to 4 of 4
    Mar 2013
    Europe
    Default Sprinter W906 2008 EZS remove
    I have in 3 hours Mercedes Sprinter 2008
    Its easy remove the EZS?
    On Vito 2008 was easy to remove EZS.
    But Sprinter????
    Thanks for Feedback
    puiu's Avatar
    Timisoara
    moore easy than vito
    puiu
  3. The Following User Says Thank You to puiu For This Useful Post:
    bersch8688 (15th March, 2014)
    smartymarti's Avatar
    Jan 2011
    cornwall
    Not sure where you are but uk it's on right hand side 2-3 minutes job
    3x t20 under kick panel , pull trim off a post remove trim and look at top of air vent 1 x t20 and another 2 at the bottom of it , remove that then there's another 2 t20 , remove outer key ring and you can pull trim away enough to get esi through
    All about the Bass
  5. The Following User Says Thank You to smartymarti For This Useful Post:
  6. #4
    Mar 2013
    Europe
    Gold Programmer 1.54 EDR Pauli Work Perfect EZS ;-)
