    kumistheru's Avatar
    Aug 2013
    Default XProg-m Repair Guide using AVR Dude. Easy and Effective
    For those who have tried to update xprog-m and bricked the xprog-m
    Follow the following steps in order to get it repaired quickly.
    1. Buy USBAsp tiny programmer from eBay or Aliexpress.com which is about $3.00 (Very handy little programmer)
    2. Install AVR Dude. ( Can be downloaded here: AVRDUDE - AVR Downloader/UploaDEr )
    3. If you have pin 2.5mm pin headers, just solder them to the XPROG BDM locations as shown in picture. This will help to connect DuPont cables directly from USBAsp to the XPROG and handy when update again.
    4. Instead of using JTAG connector, you can use duPont cables to connect USBAsp to XPROG as per picture ( it is on the RAR attachment).
    5. Connect the USBAsp to computer (Drivers will install automatically)
    6. Open the Command Prompt where AVRDude installation is located (Open as an administrator)
    7. Put Flash.bin and EEPROM.Bin files (Supplied in RAR file) to the AVRDude folder where you are working.
    8. Issue the following command.
    avrdude -c USBasp -p m64 -e -U flash:w:flash.bin -U eeprom:w:eeprom.bin -U lfuse:w:0x2F:m -U hfuse:w:0x8A:m -U efuse:w:0xFF:m
    All done. Your XProg is back to life.
    Press thanks and reputation button if this helps you.
    XProgRepair.rar
  2. The Following 20 Users Say Thank You to kumistheru For This Useful Post:
    anissss (8th October, 2017), ant21000 (17th April, 2014), autofan1965 (16th March, 2014), claudio35 (15th March, 2014), djalil (7th November, 2018), ecufix (25th October, 2024), erron (30th December, 2019), Fats (29th January, 2018), felix_fetche (15th March, 2014), hbalazs (30th September, 2018), HeXeN (19th March, 2015), hoangtu (16th March, 2014), jakesman (1st April, 2015), kadi0209 (15th August, 2014), mecadriano (16th March, 2014), mustafr (19th May, 2019), Pyromaniak (15th April, 2017), slavisac (16th March, 2014), Talleresmalaga (2nd September, 2019), things4u2get (9th October, 2019)
  3. #2
    claudio35's Avatar
    Chile
    felix_fetche's Avatar
    Baia Mare
    of course everyone of us own a UPA, better to use what we allready have.
  5. The Following User Says Thank You to felix_fetche For This Useful Post:
  6. #4
    kumistheru's Avatar
    Aug 2013
    Guys, I am in the process of preparing Version 5.45 original flash dump to upgrade your existing xprog-m < 5.45 to Version 5.45. Once ready, will post that here. This is not software upgrade, but actually the hardware.
    kumistheru's Avatar
    Aug 2013
    Isn't it better to have alternative methods to repair xprog? What about the people who don't have UPA and get their xprog repaired in cheap alternative ways?
  8. The Following User Says Thank You to kumistheru For This Useful Post:
    whiskeyman (18th August, 2015)
  9. #6
    Oct 2017
    Default Problem xprog box 5.6
    Hello friends like amdan?
    I wanted to ask for help with an xprog 5.6 that I bought and it gives me the following error: silenced device.
    I have Upa to be necessary for the repair.
    If it can be I hope they give me a repair tutorial since I'm new to the topic
    I will be very grateful for your help.
