Results 1 to 9 of 9
    Jul 2011
    Default ECU EEPROM MK4 Golf, help make virgin
    Please help, can someone make this MK4 Golf 1.9TDI ECU EEPROM virgin dump. Your help appreciated.
    May 2012
    Why you need virgin ? Pin for this dump is "06657" . Learn your ecu with this procedure:
    [Select]
    [01 - Engine]
    [Login - 11]
    For the following procedure, use the PIN of the REPLACEMENT (USED) ECU.
    • 4-digit PIN
      • The PIN needs to be entered as 5-digit number in the New Value box. For example, if your PIN is 1234, enter 01234.
    [Do it!]
    [Adaptation - 10]
    Enter 050 in "Channel Number".
    [Read]
    For the following procedure, use the PIN of the ORIGINAL (OLD) ECU.
    • 4-digit PIN
      • The PIN needs to be entered as 5-digit number. For example, if your PIN is 1234, enter 01234.
    [Test]
    • The values may change to "32000", this is normal
    [Save]
    [Done, Go Back]
    [Close Controller, Go Back - 06]
    • Switch OFF the ignition and let the car sit for ~1 minute, then switch ON the ignition again.
    • Verify that the REPLACEMENT (USED) ECU now shows the VIN and if supported IMMO-ID of the vehicle now.
    • Verify that the REPLACEMENT (USED) ECU has the same Coding as the original unit, or code it from scratch using the repair manual or coding chart in VCDS when applicable.
    Jul 2011
    I don't have the original ECU, I already know rosstech procedure thankyou.
    Jul 2011
    Car used to have immobiliser 2, but dash was changed with upgrade and has immobiliser 3, now ECU is also being changed and also immobiliser 3. If EEPROM is Virgin this can help me a lot.
    Dec 2012
    EU
    why not just do immo off?and car ready to go.
    Jul 2011
    Immo off leaves flashing immo light on the dash, also the my friend wants to maintain immobiliser security.
    Dec 2012
    EU
    ok immo light can be blocked
    Jul 2011
    Is this by immo off in the dash rather than in the ECU?
    Jul 2011
    Ok, finally my friend was able to read the EEPROM in the instrument cluster, so I manually synced immo that way. Now working.
