Page 1 of 3 123 LastLast
Results 1 to 15 of 33
    jjrp255630's Avatar
    Jun 2009
    porto portugal
    Default astra 1.9DTH need DTC off
    hi, need to remove a DTC from this ecu:
    P1109-05 Swirl Actuator Feedback Circuit High Voltage
    P0100-09 Mass Or Volume Air Flow Circuit High Input
    regards
  2. The Following User Says Thank You to jjrp255630 For This Useful Post:
    dziongas (29th January, 2016)
  3. #2
    waldi1979's Avatar
    Dec 2010
    Here you are,
    Pass PM.
  4. The Following User Says Thank You to waldi1979 For This Useful Post:
    jjrp255630 (21st March, 2014)
  5. #3
    jjrp255630's Avatar
    Jun 2009
    porto portugal
    hi, thanks, but still have one DTC P1109-05 Swirl Actuator Feedback Circuit High Voltage, can you remove it?
    regards
  6. #4
    Jul 2012
    Default astra edc16 dtc
    my test file
  7. The Following User Says Thank You to mario38 For This Useful Post:
  8. #5
    jjrp255630's Avatar
    Jun 2009
    porto portugal
    Quote Originally Posted by mario38 View Post
    my test file
    thanks but not working
  9. #6
    Babos's Avatar
    Mar 2012
    maybe ask to profi?
  10. #7
    Jun 2013
    EU
    my test file
    , nice comment btw
  11. #8
    waldi1979's Avatar
    Dec 2010
    Try it again.
  12. #9
    Jun 2013
    EU
    DTCs deleted, give it a try.
    Regards.
  13. #10
    Jul 2012
    Quote Originally Posted by jjrp255630 View Post
    I'm sorry I did this work and other times it worked well your case is different .. I hope you have solved .
  14. #11
    jjrp255630's Avatar
    Jun 2009
    porto portugal
    hi, your solution is working, i unplug swirl motor, but still dtc P0100-09 Mass Or Volume Air Flow Circuit High Input
    regards
  15. #12
    Jul 2012
    yes you're right I found my mistake
    my file is ok swirl off
    dtc 1109 off ok
    dtc 0100 is not completely off ok problem solved
  16. #13
    jjrp255630's Avatar
    Jun 2009
    porto portugal
    dtc 1109 off ok
    hi, can you send me your file fixed?
    regards
  17. #14
    jjrp255630's Avatar
    Jun 2009
    porto portugal
    dtc 1109 off ok
    regards
  18. #15
    Jul 2012
    Default swirl off dtc1109 dtc0100
    regards
    I added a few changes here I hope that now works well
