Results 1 to 15 of 17
Hybrid View
    Lithuania
    Default Toyota rav4 2012 dont see smart key
    This is double post sorry but first I think in wrong place.
    Please help to solve problem.
    I have little flood car toyota rav4 2012 2.2 dcat with smart key.
    and have 2 errors
    B2784 antena coil open-short
    B2783 immobiliser power charge malfunction Vc5 GND Short. I have no ignition.
    Need wiring diagram
    and where transponder key ampfler located
    Or any other solution could be ?
    Does possible to solve that problem with wirgin dump.
    I first time deal with smart key ........
    Please help... Pleasee
    achaccha's Avatar
    Nov 2010
    Locates the module "smart key" and read the eeprom, you also have to read the key, publish these files and we'll see what happens from there.
    antenna coil becomes the power button.
    luck
  3. The Following User Says Thank You to achaccha For This Useful Post:
    darius89 (21st March, 2014)
    Lithuania
    There immobox reading .
    inside 93c46. but I dont have tool to read smart key.
    does possible to make virgin for key self adaptation
    achaccha's Avatar
    Nov 2010
    Dear Friend
    If the vehicle is with smart key. you have to find a smart key ECU and possibly a 93c66 or perhaps be a 93c86. read the eeprom and publish it.
    regards
    gwee's Avatar
    Dec 2012
    unknown
    Quote Originally Posted by achaccha View Post
    Dear Friend
    regards
    you are giving him the wrong directions, problem is wiring etc, nothing to do with keys.
    just see the dtc you will know......
    it is a flooded car, remember
    Mar 2014
    north east of Africa
    Yes I think its electrical, check your smart ECU first (5volt ) come out of
    the smart ECU then check the start switch (antena coil).
    Lithuania
    where smart ecu located ????
    gwee's Avatar
    Dec 2012
    unknown
    under the steering wheel, nearer to the door side.
  10. The Following User Says Thank You to gwee For This Useful Post:
    darius89 (23rd March, 2014)
  11. #9
    Lithuania
    Its only fusebox ..... It inside fusebox ????
  12. #10
    Behind glovebox when it is LHD and model same as 2011.
  13. The Following User Says Thank You to autofan1965 For This Useful Post:
  14. #11
    Lithuania
    hI, i MADE COUPLE PICTURES.
  15. #12
    gwee's Avatar
    Dec 2012
    unknown
    the one in the red circle.
  16. The Following 5 Users Say Thank You to gwee For This Useful Post:
    darius89 (23rd March, 2014), iamfooser (27th March, 2014), keysph (23rd March, 2014), NiZaTroniC (1st April, 2014), super jumbe (23rd March, 2014)
  17. #13
    super jumbe's Avatar
    Livingstone
    Quote Originally Posted by gwee View Post
    I once gave up looking for immo box of Toyota rav4 when I could not find it, thanks gwee good picture.
  18. #14
    Lithuania
    Please help with wiring.... 2011 , 2012
    I have only from 2013 but it different.
    I have 2006 - 2009 but it without smart key
  19. #15
    Lithuania
    looks like everything ok with wiring
    I have one more flood same rav4 . That car ignition works ok, and car starts.
    What I need to take from that car to start (or to make ignition work) in this rav4.
