Results 1 to 2 of 2
    aliali18's Avatar
    tunis - (kasserine*Kairouan)
    Default How can open dash citroen c5
    thanks digital-kaos
    Sep 2013
    Remove screws top of dash, remove top cowling, remove the controls (below vents)
    This will remove all trim around dash, then remove the two screws which are revealed.
    Then you need to remove the bolts to lower the steering more than normal which will allow dash to be removed.
    Bit of a pain to do but well worth, this can go OBD DASH+BSI using some tools now
