Page 4 of 4 FirstFirst 1234
Results 46 to 54 of 54
  1. #46
    Aug 2021
    Czech Republic
    Quote Originally Posted by magdyman View Post
    Hello
    if dump not correct or corrupt.
    i send you 2 dumps are pairs
    you can rest immo and ecm by T300
    if you need immo off for this car i have a dump and tested %100 ok tell me
    Good Luck
    Thanks, this is so helpful. I'm gonna try this and I hope it will work. I have the same car and immo box (2007 yaris 1.3 2nz 89780-52060.with eeprom 93c66)
  2. #47
    Aug 2021
    Czech Republic
    Hello
    Good Luck
    hi! Would it work if the immo box originaly had a 93c66 and I copy the virgin dump into a 93c56 and use it instead of a 93c66? I'm asking this because I think my 93c66 if defective and I have a 93c56 at hand.
  3. #48
    Aug 2021
    Czech Republic
    Please, I have the same problem and I need your help. I have a toyota yaris 2007 1.3 manual with eeprom 93c66 and I lost the last key. Please help me with the immo off please please!!
  4. #49
    Aug 2021
    Czech Republic
    Quote Originally Posted by ttzag View Post
    try this immo off
  5. #50
    Vietnam
    Quote Originally Posted by VernonS View Post
    Post your ecu eeprom 93c66
    Visit my homepage
    If my reply's useful, give me 1 thanks + reputation
  6. The Following User Says Thank You to batbatdieu For This Useful Post:
    VernonS (13th September, 2021)
  7. #51
    Aug 2021
    Czech Republic
    Quote Originally Posted by batbatdieu View Post
    Thanks for showing up, here is the ECU. Immo eeprom...
  8. #52
    Vietnam
    need file from ECU Engine control unit, not immo
    Visit my homepage
  9. #53
    Aug 2021
    Czech Republic
    Okay. I've checked the engine ecu and I could only find S93a66 and I am not sure if i can use my home made serial programmer.
    The programmer I made according to circuit on: https://www.clublexus.com/forums/es-...apped-ecu.html
    would this work or will it cook the eeprom or even the serial port?
  10. #54
    Member obdshop's Avatar
    Jun 2016
    EUROPE
    can you send me the file please or posting again ??
