Results 1 to 10 of 10
    stalonerambo
    Guest
    Question how add a remote control on golf 2001
    hi friends need one information, what step i need to follow to add a remote control on vw golf 2001car has 2 keys, i tried ignition ,on spare key, and one key and remote control on drive side, but without any sucess, i was thinking , is it possible add by obd port?
    have you tried clearing all of the remotes before programming by the on board procedure? It should keep overwriting the fourth position if you try to add too many remotes but i believe hitting the button 5 times in a row clears it (have to check). It can be done via obd, I have done a ton of these via vcds, quick and easy procedure If it doesn't work it is like the wrong remote. In north america, 99.5-2001 is the old remote (either round type with an 'F' as the last digit of the part number) or the square button ('T' is the last digit of the part number) but 02+ has the newer remote, they are not interchangeable.
    Top Poster key point's Avatar
    UK
    Quote Originally Posted by stalonerambo View Post
    Yes, remote is programmed diagnosticaly via OBD.
    foxtec800's Avatar
    Read this and it should solve your issues
    Ross-Tech: VAG-COM: Remote Control Matching Info
    obdsystems's Avatar
    Oct 2013
    U.K, not the E.U.
    You can also do manually with 2 keys. sometimes easier
    Mar 2014
    Greece
    Manual Procedure
    1. Switch Ignition ON and leave the key in the ignition.
    2. Mechanically lock the vehicle using the Drivers door using a second
    key.
    3. Using the remote control press the Unlock button once, and the horn
    will sound once.
    4. Wait 6 seconds and press the unlock button once to activate the coding
    procedure. The remote control will now be programmed.
    NOTE : When performing programming on additional remotes the procedure
    is the same, except you press the unlock button 2, 3 or 4 times for the
    different remote.
    For example : If programming 2 remotes press the unlock button twice with
    a 1 second interval between each press, repeat for 3 and 4 remotes.
    5. Switch Ignition OFF.
    6. Remove key from ignition and check for operation.
    7. The coding procedure can be repeated up to 4 times for additional remotes.
    8. The ignition must be switched OFF between programming each remote
    control.
    Jun 2011
    devon uk
    if 2 keys method doesnt work its very often due to dry/cold joints in the door lock.
    car doesnt reckognise you have locked the car from outside and doesnt get into coding mode.
    try obd.
    obviously you need correct remote
    Oct 2011
    ive done some from boot lock to get into programming mode, if there is one that is
    Oct 2011
    this was on audi though, but worthwhile trying on all doors sometime I recon, regards
    stalonerambo
    Guest
    thanks friends, i solved it, bad remote, now , new remote work like a charm,
