Results 1 to 13 of 13
    ray-ray's Avatar
    Default New pin code tool
    VPC-100 Vehicle PinCode Calculator have no idea on how it works or region cars are from.
  2. The Following 2 Users Say Thank You to ray-ray For This Useful Post:
    Automat (1st April, 2014), jebo (1st April, 2014)
  3. #2
    DK Veteran Automat's Avatar
    Chuichu village, AZ
  4. The Following User Says Thank You to Automat For This Useful Post:
  5. #3
    Jan 2014
    VIN -> PIN calculation has a very limited make support, same as ICC using the same database
  6. The Following User Says Thank You to sigmabit For This Useful Post:
  7. #4
    Nov 2012
    Wait untill the asians crack this.
  8. The Following User Says Thank You to 912secured For This Useful Post:
  9. #5
    siyadk's Avatar
    Dec 2012
    This tool is add on for skp900 programmers.. As of now, kia hyundai pincode 2008+ works. This is what the dealer claims. It will released in the market within a month
  10. The Following User Says Thank You to siyadk For This Useful Post:
  11. #6
    camelgd's Avatar
    Jan 2011
    South Illinois
    Seems to have a big hole in it called Chrysler-not listed!
  12. The Following User Says Thank You to camelgd For This Useful Post:
  13. #7
    aassfour's Avatar
    May 2013
    kensington
    another item to the bin
    The only place success comes before work is in the dictionary.
  14. The Following 2 Users Say Thank You to aassfour For This Useful Post:
    amissahking (22nd September, 2016), Automat (1st April, 2014)
  15. #8
    Chuichu village, AZ
    In The link I posted the seller says it uses 20 tokens at a time, that's ridiculous........
  16. #9
    The token consumption rate in the web mode is two times of that in VPC-100 machine. For example, if calculate PINCODE for Ford need 10 tokens in VPC-100 machine, then it need 20 tokens in website mode.
    just register and check
  17. #10
    Chuichu village, AZ
    Bump...... Anyone actually using this? It do newer Hyundai pin codes?
  18. #11
    Quote Originally Posted by Automat View Post
    HYUNDAI Immobilizer code calculator-VPC-100 Vehicle Pincode Calculator
  19. The Following User Says Thank You to paul_12345 For This Useful Post:
    Automat (28th October, 2014)
  20. #12
    Chuichu village, AZ
    Without web?
  21. #13
    Without web?
    Note:Web user need 16 tokens. VPC-100 machine user need 8 tokens only. Buy a hand-held VPC-100 machine now.
