Why when I try to do the online renewal it says renovation not allowed . Correct date etc. How do I fix please
need help not run my clone
Hi my fgtech 3 china clone not working win7 low voltarge and xp+dongle not run soft
I have Galletto V53 such as this
When I change date I can run EOBD2.exe without dongle (v53 and v54) but I have LOW VOLTAGE problem.
USB FG FIX changes nothing.
Tool number: M0475
Can anybody help me to run V53 with v54 software(or v53)?
You connect tool to obd to feed it? Or just to usb?
Regards,
Usb and OBD.
Red LED lights.
V53 running with v54 sw will not work as v54.
The cars added in v54 will not be read by v53 unit... Tested.
buy a v54 from car-prog if you want to run it good without errors
at me galletto v54 writing:update as soon as possible,and cant run it...
where is problem please?
thanx
skoda 1.2TSI SIMOS 10 not working with v53 china by obd but works with v54 euro.
this is the only difference that i have tested this days
a12arm (4th March, 2015)
Waldi is usb FTDI configuration for shore !
what SW do you use ?! the one that came width the tool ?!
My work is my life ART TECH GARAGE
Two days ago, without reason I have the same problem (on the laptop I only have Win XP SP3 and FGtech V53). Nothing gives configuration FTDI and "USB Fix"
http://www.ftdichip.com/Support/Documents/DataSheets/ICs/DS_FT232R.pdf
page 14 \ FTDIChip-ID™:
The FT232R also includes the new FTDIChip-ID™ security dongle feature. This
FTDIChip-ID™ feature allows a unique number to be burnt into each device during manufacture. This
number cannot be reprogrammed. This number is only readable over USB and forms a basis of a security
dongle which can be used to protect any customer application software being copied. This allows the
possibility of using the FT232R in a dongle for software licensing. Further to this, a renewable license
scheme can be implemented based on the FTDIChip-ID™ number when encrypted with other information.
This encrypted number can be stored in the user area of the FT232R internal EEPROM, and can be
decrypted, then compared with the protected FTDIChip-ID™ to verify that a license is valid. Web based
applications can be used to maintain product licensing this way. An application note, AN232R-02,
available from FTDI website (www.ftdichip.com) describes this feature.
I think that the "USB fix" does not change the data in eeprom ftdi, but converts data exchange between FTDI - PC ....?
Now V53 will not start, and the V54 is inactive buttons ...
I have two identical fgtech and it is the same. The installation on another laptop does not work.
Is there any solution? It will help anyone?
mexanico1971 (27th April, 2014)
If sw not recognize serial pls check mcu solder.
Probably mcu is bad soldered to the pcb
