I am trying to Read and Write a Sirius32 ECU from Renault Megane on the bench. It stops at 75%... Any ideas please?
Knowledge is to share... so if I have helped just press [Thank You + Rep.]...
speedy100 (3rd January, 2019)
Thanks!
I use this setup:
speedy100 (4th January, 2019)
And more models and ecu types are workable:
11/12 - OBD driver SSangyong Delphy DCM3.7 Read/Write, Checksum
11/12 - OBD driver for Ferrari 458 Italia MED9.6 Ecu Master and ECU Slave Read/Write, Checksum
10/12 - OBD driver for Fiat/Alfa/Lancia Twinair/Multiair 8GMF and 8GSF Read/Write, Checksum
10/12 - OBD driver for Mazda 5, Mazda 6 2.0 Diesel ECU RF8x Read/Write, Checksum
10/12 - OBD driver for Mazda 5, Mazda 6 2.0 Diesel ECU RF7x Read/Write, Checksum
09/12 - OBD driver for Simos 10.xx VAG 1.2 TSI Read/Write, Checksum
09/12 - OBD driver for CRD 3.xx Mercedes 2200 CDI Read/Write, Checksum
09/12 - Simos PCR2.1 VAG 1.6 TDI Unlock Boot Tool - Read/Write EEPROM
09/12 - OBD driver Simos PCR2.1 VAG 1.6 TDI Read/Write, Checksum
08/12 - RSA recognition Peugeot Bipper
08/12 - RSA recognition Citroen Nemo
08/12 - OBD driver Driver for writing Bosch EDC16C34/5 Peugeot Bipper Read/Write, Checksum
08/12 - OBD drive Driver for writing Bosch EDC16C34/5 Citroen Nemo Read/Write, Checksum
07/12 - OBD driver Delphi DCM3.5 for Tata Safari Read/Write, Checksum
07/12 - Checksum recognition for DCM3.7 Ssangyong
07/12 - Checksum recognition for DCM3.7 Opel and Saab
07/12 - Checksum recognition for DCM3.7 Kia and Hyundai
07/12 - Boot Visteon ST10F275 RX-TX Mode
07/12 - Boot ME7.9.10 ST10F275 RX-TX Mode
06/12 - Checksum recognition for Denso Subaru Tribeca
06/12 - Boot Mitsubishi MH7203 Hyundai
06/12 - Checksum recognition for Denso Nissan L200
06/12 - Checksum recognition for Denso Nissan X-Trail
06/12 - OBD driver Opel Simtec75 CAN Read/Write, Checksum
05/12 - OBD driver Porsche SDI3 CAN Read/Write, Checksum
05/12 - Corvette Utility CAN for change VIN, Code Align, Erase Errors
05/12 - Corvette Utility VPN for change VIN, Code Align, Erase Errors
05/12 - OBD driver Renault SID305 CAN Read/Write, Checksum
05/12 - OBD driver Maserati ME9 CAN Read/Write, Checksum
04/12 - Tool Boot Hitaci Phase 3
04/12 - Tool Boot Hitaci Phase 2
04/12 - OBD driver Fiat ME17.31 CAN Read/Write, Checksum
04/12 - Boot Mitsubishi for L200 MH8102F
03/12 - Boot Mitsubishi for Lancer EVO MH7202
03/12 - Fiat MJ8DF CAN Serial Injectors
02/12 - OBD driver Fiat MJ8DF CAN Read/Write, Checksum
02/12 - OBD driver Fiat MJ8DF K-line Read/Write, Checksum
02/12 - OBD driver Mercedes Delphi CRD2.xx CAN Read/Write, Checksum
01/12 - OBD driver Ford Delphi DCM3.5 CAN Read/Write, Checksum
01/12 - OBD driver PSA Delphi DCM3.5 CAN Read/Write, Checksum
01/12 - OBD driver VAG Simos 3xx Boot mode 29F400 C167 Read/Write, Checksum
12/11 - OBD driver VAG Simos 9.1 Boot mode 29F400 C167 Read/Write, Checksum
12/11 - OBD driver VAG Simos 7.1 Boot mode 29F400 C167 Read/Write, Checksum
12/11 - OBD driver VAG Simos 33 K-line serial Read/Write, Checksum
12/11 - OBD driver VAG Simos 32 K-line serial Read/Write, Checksum
12/11 - OBD driver VAG Simos 3PG K-line serial Read/Write, Checksum
12/11 - OBD driver VAG Simos 3PE K-line serial Read/Write, Checksum
12/11 - OBD driver VAG Simos 3PD K-line serial Read/Write, Checksum
12/11 - OBD driver VAG Simos 3PC K-line serial Read/Write, Checksum
12/11 - OBD driver VAG Simos 3PA K-line serial Read/Write, Checksum
12/11 - OBD driver VAG Simos 9.1 K-line Read/Write, Checksum
11/11 - JTAG MPC55xx
10/11 - New password Tricore Tprot V08-10
10/11 - OBD driver Renault Valeo V40, Read/Write, Checksum
10/11 - AUD Renesas
Hi Guys,
I bought this China Clone
https://www.ebay.de/itm/253976392710 (itīs 0386)
And tried to read a Ford Focus MK3 with MED17.2
So the Driver for the Focus is not listet.
Can I - or which Tool Boot Mode have I to use?
Hi, I have a galletto 4 VD300 (Chinese) with the AES software provided by fantomel and I am trying to make a clone of a Bosch MG7.9.8 ECU (1600cc accent for elantra 1600cc). I could copy the files in boot mode (micro + flash) of ECU of the elantra: the one of the automatic transmission and the motor, both of 2097152 bytes. I can install the file of transmission on the Accent ECU without problem, but the engine file only install a half: write the firmware, but the flash maintains the original accent. When the engine microprocessor is read, it reads two files, but when you write, you just write one. Does anyone know why that happens and can help me? Does not allow the galletto to clone the ECU MG7.9.8? The eeprom I could read and write using the MinPro100E without problem. Thanks in advance!
