Page 94 of 95 FirstFirst ... 448489909192939495 LastLast
Results 1,396 to 1,410 of 1424
  1. #1396
    Jul 2017
    EDC 16 Simos3,2 pinout please
  2. #1397
    Central Germany
    Hi I got a chinese Galletto V54, reflashed it, changed resonator and it works.
    Now I have a problem with my Audi A4 2009 ECU. It is a MED17.1 via CAN
    I can read and write this ECU in Bootmode with Galletto very well.
    But I cannot read or write via OBD. Neither on bench with disabeld immo or in car.
    Galletto always tells me that ECU-wakeuo failed. Same issue with MPPS16.
    What could be the problem? Has this ECU another protocol? I am nit sure if the problem is on ECU or Galletto-side. Bootmode works great.
    Kind Regards,
    Yogi
  3. #1398
    Newbie Orchid70's Avatar
    Aug 2015
    SWEDEN - Sjöbo
    In the learning business and mostly looking for a tool for reading and writing (files that someone else have but together for me =)
    In Sweden and have cars from 2000-2017.
    Would this be a good option for me:
    http://www.obdii365.com/wholesale/fg...u-version.html
    Thanks!!
  4. #1399
    Member turbo16v's Avatar
    Mar 2018
    low quality board or clone of cloneAttachment 694027
  5. #1400
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    Quote Originally Posted by Orchid70 View Post
    Thanks!!
    Thats the best chinese pcb that is out.
    If i Helped you,use thanks and rep button to thank me back
  6. #1401
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    Quote Originally Posted by turbo16v View Post
    Search for Fantomels threads,you can rework it somehow and make it a lot better!
  7. The Following User Says Thank You to Stelaras26 For This Useful Post:
    turbo16v (26th February, 2020)
  8. #1402
    Mar 2018
    [QUOTE = Stelaras26; 3805886] Suche nach Fantomels-Threads, du kannst es irgendwie überarbeiten und es viel besser machen! [/ QUOTE]
    I can't even install proper capacitors because there are no holes in the board
    fantomel did a great job here!!
  9. #1403
    Aug 2008
    that board of yours is crap sorry
    never seen 1 with smd caps instead of the normal electrolitic caps before
    if there is no through holes for normal caps then you could replace the ceramic smd caps for proper smd eletrolitic caps instead which will work just as good
  10. #1404
    Apr 2016
    GB
    hi....i have to read KIA ECU EDC15C7 this one not have support on Ktag......i have Geleto V54 clone this device have support with EDC15C7 Alfa remo please some have how to connect ECU with Geleto......please help......i try to read AM29F400 it is password protected....
  11. #1405
    Jun 2013
    EU
    That edc15c7 you can read with any tool that supports C16x processor bootmode. Ktag should do if you choose ME7 ecu with same flash chip. Also galletto read it bootmode selecting ME7 protocol.
  12. #1406
    Apr 2016
    GB
    thanks man, KESS can read by OBD2 Kia ECU EDC15C7.......and Gelletto also read EDC16C2 on table only have to ware Kline and +Ve and -Ve
  13. #1407
    After update 386 to 475 fgtech v54 will read AcDelco E83? (or other mpc5565).
  14. #1408
    May 2018
    Actually the PCB from photos above, can properly be reworked. I bought SMD electrolitic caps with proper capacitance, removed from them plastic base, and soldered "standing" with theirs legs on pads on board. It works like a charm. Never failed.
  15. #1409
    Sep 2016
    Lightbulb Galleto V54 jumper location?
    Can anyone help me how to connect to motherboard on this tipe V54?
    I founded the RX, TX, and Gnd but i dont know how to use that jumper pinout so i could flash the LPC..
    Thanks!
  16. #1410
    GB
    Hi.Can you tell me how to connect it, which side is to go to the galletto and which side to ecu...?20201117_225443.jpg
