here you go. Good luck!
Hi all,
Can someone share the schematic in order to repair it ?
My galetto 4 0475 was working perferct, but now BDM side doesn't work anymore, only OBD side.
Relays seems to be ok...
Thanks.
Regards.
Does anyone have a working link to the V55 software ?
kasia ovi (7th January, 2024)
I received a GALLETTO 4 V54 from China.
It doesn't work on OBDII.
I opened it, seeing how it is inside, I did not like it, I decided to rework it.
I have to replace the three relays, the transistor Q20 ZVN2106A, because the Chinese have installed ZVP2106A incorrectly.
IMG-9e38757f445d59ac9906fd723204ac1c-V.jpgIMG-20220328-WA0003.jpg20220328_180233.jpg20220328_180157.jpg
Please share what more can be done to improve and upgrade the GALLETTO 4 V54.
double post, see next post...
i just received my Galletto v54 0475 version but the RX/TX leds were not blinking during operation (just a short blink when plugging in the usb cable) .<br>
I solved this problem by adding 2 10 kohm resistors to the pcb next to the NXP test points , you will see 2 empty locations for these resistors.<br>
Now the leds are blinking during operation (changed them to yellow and green like in the software display) .<br>
I also added a led at D4 next to the power led ( empty on pcb) - this led will light when the usb cable is connected.<br>
not nessesary but fun to have a extra led lighting....
There were also two ZVN210A fet transistors missing om my pcb, i ordered them to see if that makes any difference but i see them mounted on most pcb's so i guess they will serve a purpose...
I have used this tool for many years, it works very well with windows xp, less well with windows 7.
great for edc15 and edc 16 and edc17 not recent pcr 2.1 ok
I advise you not to use it for ecu Marelli mjd it has walled many to me
File Service Dpf Egr AdBlue Dtc Tva Swirl Kat Off and more
Did you fixed it? I have the same problem. I remember that it worked after I updated it to 0475. On OBD (bench) it worked well on same Ecu that I tried on BDM. Also I tested with 2 EDC16 ecu, Chevrolet and VAG.I checked the cables. After I click on Connect, relay clicks then error appears. There is an error, eprom micro not supported or something like that.
I reinstalled the software few times, now I realized that is installed in Program Files, not on C:\FgTech.
Computer is the same as before, W7 X64.
hi does anyone have working software for this fgtech please my laptops lost everything and i cant find any software for this machine please and thank you
Attached v54 0475 (not 0386).
Feel nice if thanks and rep!
No pass of course.
gagi08 (21st May, 2024), Jozua (5th April, 2024), nesok78 (10th February, 2024), stuart6363 (1st June, 2023), vladim1 (20th February, 2024)
Hello everyone! First of all, sorry for my poor English.
I have an old Galletto type 4 device,
I can't identify it, but I bought it in 2015.
Can it be updated so I can read newer cars?
Could you possibly help?
Bro
