read good file and post.
Hello
I have a audi a3 2.0 tdi bkd 2008 year, the car have a poor hot start, I change battery and starter but identical situation
I read the ecu edc16u34 with galletto v51, the file size is ok 2mb. but I load in my ecmtitaniun 1.61 and not find the right driver for this file, Not sure if the file is good read or if titanium 1.6 not have this driver
can any check this file, and repair hot star and calculate checksums?
I try to write back in the car wiht galleto v51
thanks in advance and best regards
ALL TUNING.
THE BEST OR NOTHING. THANKS + REPUTATION .
Hello
but this file is not ok? galletto not read ok?
regards
File not good, A3 BKD fits EDC16U1 or EDC16U31 as far as i know. I would bet EDC16U1
the ecu is 03G906021LG I THINK THAT IS EDC16U34 sure that is 16u31?
regards
one picture
Have you made ID before read?
Check if that number matches the one readed in the ecu info with fgtech.
Regards,
That picture you post is not from you car, i guess but from a second hand selling site.
Regards,
Hello, I put the pic for that see that is edc16e34, I read identification with vcds and display 036906021LG
Go to try new read with galletto
regards
you try to modify with vag-com...
login12233, adaption ,ch 01. enter 300,and work.
I try to new read with galleto and not posible select tables or entire file, this options are disable in v51, what util can read ok this ecu by obd? and write ok by obd?
regarsd
file ise wrong .. correct file is attach 2 file . 1. file fw 9558 current 2. file fw 9828 . maybe hotstart problem fixed fw 9828 im convert vw database sgo to bin fle .. pass pm
https://mega.co.nz/#!pZtkEJwQ!2Es97U...Rril3Zbr4srgzw
https://mega.co.nz/#!dJUCGSJC!qNjiog...oqe5SmrELwceQQ
audiomeca (5th April, 2014)
Hello, thanks for the links but the car have already 9828 soft version, and not start ok when hot
I need read and try to modify
