Results 1 to 3 of 3
    Feb 2012
    Default NEED HELP PEUGOT 407 PLEASE
    hello, please i need help on a peugeot 407 2L 136 hp, siemens ecu 803A , BSI jonhson control
    the immo problemme
    I tried to reprogram the key, it does not work, I have the correct code ummo
    I tested the ring : ok
    I used a 307 COM2000
    I arrrive to programme a key but the car does not start
    I changed the bsi (vergin with ecuvonix) and bsm
    I test the ecu in another car ; ecu ok
    I reprogram the key, but I Still the problem immo
    paramettres
    bsi ::
    aprise key: 2
    ecu;
    Waiting bsi response
    Have you any idea?
    THANKS
    electrones's Avatar
    Feb 2012
    Around C.V
    Hi friend
    I think ECU has lost communication with the BSI, checks the wiring or can be problems on the line CAN BUS.
    Check on real data communication between them.
    Try to change ECU!!!
    Do you have DTCs?!!?
    Good luck
    Cheers
    Press "THANKS" button. just one click, CHEERS
  3. The Following User Says Thank You to electrones For This Useful Post:
    amourh59 (7th April, 2014)
    tqnata83's Avatar
    Dec 2013
    original communication ECU<->ABS<->BSI
    try to put direct wire ECU BSI
    new name but old dk member
