Page 1 of 2 12 LastLast
Results 1 to 15 of 16
    Jun 2011
    Default help pls to know transponder typpe for vectra c 2002 model
    hello friends pls i have opel vectra 2002 model all keys lossed i need to know what type of transponder i have to use to program on it
    i got the pin code from the dashboard and its ok so pls just i want to know the transponder type
    thanks in advance
    Atex31's Avatar
    Feb 2011
    UK
    It is an Id46 transponder,
    Best to use an original remote key with onboard chip, the car will not recognise a standard PCF7936.
  3. The Following User Says Thank You to Atex31 For This Useful Post:
    elmaalouf (8th April, 2014)
    Jun 2011
    thanks friend but i dont have a new opel rem ote can i use a used one?
    Dec 2010
    Nottingham
    No , you need a new remote key.
  6. #5
    Jun 2011
    can it be done using pcf 7936 ?
  7. #6
    Atex31's Avatar
    Feb 2011
    UK
    See 1st reply my friend.
  8. #7
    Dec 2010
    Nottingham
    2002 can be a funny year if you have a late registered vehicle , ive seen some older vectra B on this year as well as the newer vectra c .
    if as i suspect this is the new vectra C then no you cannot use a 7936 chip , the vectra c must have a remote key coded to it where the chip is integrated on the circuit board.
    The only way you can put a non remote key to this is by using a small board instead of a remote key , but these are expensive , you can buy these from hickleys in the uk item zed46 , but by the time you buy this and the blank its only ?18 cheaper than a full remote key .
    2nd hand remotes are no use to you , a plain 7936 chip is no good to you , a non remote key is only an option if using the zed46 board , my advice is forget on the cheap and program a new remote key to it.
    if its a late registered vectra b which i doubt , but possible , then it will use an id40 chip and a standard non remote key can be coded in , the remote will most likely be a 2 button and 2nd hand remotes can be used if an older vectra b model.
    so your options depends on whether the 1st of the vectra c models or the last of the vectra b models , if vectra b you can do on cheap , if vectra c then order a new flip remote key.
    as you have stated yours is a vectra c 2002 , then you must forget a 7936 as wasting your time , forget used remote as wasting your time , you need a new virgin remote key to get this sorted out
  9. #8
    simaservis1108's Avatar
    Aug 2013
    Serbia,Belgrade
    Can anyone give link for that Zed46? I cant find it anywhere.
  10. #9
    Dec 2010
    Nottingham
  11. #10
    Aug 2013
    Serbia,Belgrade
    That is what I was looking for.I will try to build it tommorow,and test on my car.Thank you for the link.
  12. #11
    armpower's Avatar
    Jun 2009
    Italy
    Hallo
    Simaservis have you tried to build this small circuit?
    I have a Vectra C and need a new spare key, but without remote.
    I've read that Vectra C need a remote with precoded pcf7936 and a key without remote can't work.
    So I ask to you if you have sucessfull build this circuit and what type of pcf7936 have you used ?
    I meant a pcf7936 that some china seller sold as suitable also for renault car?
    Many thanks.
    Cheers
  13. #12
    Mar 2010
    simaservis.........Forget it, just buy the remote, the zed46 is a bad idea it doesnt even fit into any key its to big, too expensive. You CAN'T use a 7936 at all either.
    it must be a 7946 precoded on zedbull or similar so the locking works
  14. The Following User Says Thank You to pianoman58 For This Useful Post:
    armpower (3rd September, 2014)
  15. #13
    Sep 2014
    hello friend pls help how can i get the pin code for a same opel vectra c ?
  16. #14
    Sep 2014
    pls help need pin code for opel vectra c 2002 model attached the dump of the dashboard
    thanks in advance
  17. #15
    gwee's Avatar
    Dec 2012
    unknown
