Page 1 of 5 12345 LastLast
Results 1 to 15 of 61
    soxten's Avatar
    Mar 2013
    Default Saab Trionic 8 how to change VIN and IMMO code?
    Need to replace a ECU on a Saab 9-3 2004 2,0T but have some problem...
    I can read flash by FGtech V53 on canbus.
    I can open bin-file in T8suite.
    I can see VIN and immobilizer code BUT I can`t change it... (gray marked in program)
    I don`t have Tech2 and TIS for coding in car, only ECU on bench.
    .bin file are hex coded so I can`t see and change info...
    Did try to connect OP-Com China and choose Vectra and Trionic ECU but can`t change anything.
    Even try`d Saab special at bottom of year in Op-Com but don`t work...
    Is it possible to fix this?
  2. The Following User Says Thank You to soxten For This Useful Post:
  3. #2
    soxten's Avatar
    Mar 2013
    Plz someone?
    Need more info.
    Is vin and immo code stored in flash or i somd of the 2 mcu as is on the pcb?
    soxten's Avatar
    Mar 2013
    I have desolder flash and read it by Wellon programmer.
    Flash is Xor decrypted.
    I did clone flash to a ECU from 2003 (not same partnumber!...) and car starts and run perfect
    After a test drive Check engien lamp is lightning in dash and I get "wrong in ecu" and this is from wrong partnumber on ECU.
    SO..... If you clone flash you can swap ecu!
    I still need to find a program to change Immo code + VIN in the Xor crypted flash file.
    T8suit cant change this.
    DK Veteran maybach_'s Avatar
    EU
    You can reset this easy m8 with opcom no need to open the ECU...
    Bat after you most sincronize ECU with tech2 in car..
    Lycka till!
    Be allways Thankfull!
    soxten's Avatar
    Mar 2013
    Opcom china ask for pin to reset, not possible!
    Pin Opel 4 digit and Saab 10-15 digits....
    I have done this 4-5 times (clone T8 ecus).
    Contact me and I can help you.
  8. The Following User Says Thank You to bluetaily For This Useful Post:
    rgnaya (22nd March, 2018)
  9. #7
    EU
    4 digit opel code you can se in t8 suite from ecu dump and reset
  10. #8
    soxten's Avatar
    Mar 2013
    But in T8suit giv both digit and number.
    In opcom you can only type digits.
    Or?
  11. #9
    EU
    No no no in opcom you can type digit and number also if you do not se the code in t8 suite so yo can take out from VIN
  12. The Following User Says Thank You to maybach_ For This Useful Post:
    mohamed maila (25th February, 2023)
  13. #10
    Aug 2012
    LATVIA
    help me please
    trionic 8 i need clone this ecu...
    saab
  14. #11
    soxten's Avatar
    Mar 2013
    Please I have still problem to clone this ecu.
    Please help!
    If I only clone flash car dont run correct.
    It starts and run but very bad....
    Christian Johansson via Iphone 5s
  15. #12
    Hi, for full good working clone T8 You must program ECU by BDM first, and after that by CAN with the same file.
  16. The Following User Says Thank You to electrix For This Useful Post:
    spiridonas (28th November, 2020)
  17. #13
    soxten's Avatar
    Mar 2013
    Why this problem?
    Where is all info stored?
    All other ecu we can clone (exept edc17 as we do immo of on)
    Have someone try to copy mcu in ecu?
    We may(?) need to clone flash and mcu
  18. #14
    T8 has 2 MCU, but all info is stored only in external flash (29BL802CB). I wrote above how to make correct clone of that ECU. Last I did it about one week ago. Tested and works for sure.
  19. The Following User Says Thank You to electrix For This Useful Post:
  20. #15
    soxten's Avatar
    Mar 2013
    Electrix, what file to program after bdm reading?
