Results 1 to 5 of 5
Hybrid View
    V.I.P. Member Curious123's Avatar
    Apr 2008
    tar.gz is the linux equivalent to winzip. If you copy the file to the var/tmp folder on your dreambox and than on your remote press the blue button and select 'manual install to install the file onto your box.
    May 2008
    Since we're on the topic, tar.gz is essentially a two step archive. The first is the tar (or so called tape archive; yes, the name comes from when tar was basically only used to make backup archives on magnetic tapes) and the second is compression of that tar with gzip. You can extract the tar.gz on your Dreambox (should you be so inclined) by running:
    tar zxvf services.tar.gz
    or to do it as a two step process... just uncompress the tar with:
    gzip -d services.tar.gz
    which will produce a services.tar, and extract the tar with:
    tar xvf services.tar
    Have fun. **
