Results 1 to 5 of 5
    Default Nissan Rogue 2008 and up remote programming options
    Hi M8's
    Good Day,
    What are the options available to program the remote part of the Nissan Rogue 2008 and up.
    Is it possible to do it with any cheap clone on the market?
    Please share!
    ray-ray's Avatar
    Ikey remote gets program same time as the immo. (Type 9 with a twist ignition or type 10 push to start only) you must read bcm and convert it to pin code. Next you must release the steering lock, that will clear all keys at that point. Next you must introduce the ikey make sure you have fresh battery in the ikey.
  3. The Following User Says Thank You to ray-ray For This Useful Post:
    neverquiet (9th April, 2014)
    Thanks ray-ray for your reply,
    How about the ones that with metal keys like the following picture, Thanks
    Dec 2011
    United States
    Prox programs both remote and xponder the same time. IKT (twist knob) programs key section then remote section is programmed in additional steps. That looks like a standard key remote my program obp not sure.
    siyadk's Avatar
    Dec 2012
    you can program the remote part by manual procedure...have done plenty of nissan sunny late 2013 models which has same remote type as shown in picture. I think it works if its Japanese cars
    try this procedure and lets know
    2009 Nissan Sentra
    I know it says rogue cant be programmed via manual method, i personally have done similar remotes on different cars...worth a shot
  7. The Following User Says Thank You to siyadk For This Useful Post:
    neverquiet (12th April, 2014)
