hi.
one question,can i take this images for QboxHD also?
This is The latest Enigma2 image from Tideglo, modded by PKT and DDTKLAN Teams.
This is for USB stick and NOT Flash. IPBOX900 IPBOX910 IPBOX9000
BASED ON
ENIGMA2 by Tideglo 0.5.0
PKT 5.0.a
Code:19.07.2009 hours 19,20 Modernized plugin to MediaCenter 19.07.2009 hours 20,40 Modernized plugin to VLCPlayer 19.07.2009 hours 20,50 Added to some packages python2.5 for future uses 19.07.2009 21,12 hours WeatherInfo in MediaCenter for the main Italian cities 19.07.2009 hours 22,00 Added plugin TimershiftSave 22.07.2009 hours 12,10 Arranged BUG on ESCAPE from MoviePlayer 22.07.2009 hours 12,11 Modernized to List channels DDTKLAN 13-19
hi.
IscanMod E2 v804
Fixed:
- Kerni-HD1-Red Scin
Added:
- Allien-Hd Scin
- New Mediacenter
- Plugin NetworkBrowser
Language Blu-panell set default is English
Code:http://rapidshare.com/files/262578619/IscanMod_E2_v804.tar.gz
Version 0.5.5
Ok from this release you will get a nightly build image. (this means i will not support stupid options like: panels, plugins and so on)
Soon a sifteam image will be out with panel and many options enabled.
I choose this way because i want that cuberevo community increase more! Many teams are involved in E2 now, so
each one can do his choice, and sifteam images will be out with another image (obviously based on the same Nightly build image version)
I will publish also how to build your own flash image, so every team can do it.
- new bootlogo (thanks arken)
- added bulgarian language
- added autofs
- added openvpn
- added openssl library
- added 576i to AutoResolution plugin
- added ftpput
- added ftpget
- added netstat
- "fixed" signal level on tuners
- teletext exit with "exit" button on remote
- fixed aspect on screen when exiting from tele text. If watching 16:9 format, it is shrinked, so looks like 16:6 or something
- fixed positioner setup
- fixed teletext subtitles
- remapped few buttons
- fix for DVB subtitles wich were not shown on some skins
- fixed bootlogo view on SD television
- fix the issue with stopping playback while it is paused
- incorporated the new web interface version (04/06/2009)
- fixed fast forward for MP3 in MediaPlayer
- enabled forwarding the second transport stream to the decoder
- fix avi 23.976fps/24.976fps/29.976fps
- avi: fix audio track selection early support for redirecting in http streaming
- added .rec extension file support
- CI cam drivers handling should now be better
- lot of fixes on PicturePlayer
- lot of fixes on MediaPlayer
- modified epgCache load to allow the load on e2 starts (now crossEpg works perfectly)
- added estonian language
- allowed to record/stream multiple c hannels from the same transponder (FTA only)
- There were a bug when a freeze happen on HD and SD channels, that bug showed you a full green pixel screen or an image repeating loop,
well this is bug was really hard to find for me and i'm not sure i've found all the cases when it happens, so... let me know if it happens again.
Many people asked me to add smart card drivers made by pacco, but i've not did them, so i will not add them like part of my images.
They can be added manually by everyone and each team made the possibilty to download and install them, so i will not add them until
i will make my own version (wich i don't know when and how it will be ready, you can use the pacco's version wich is good enought)
Enjoy it! Tideglo
Thanks Tideglo and E2 teams
rapidshare download link here
Changes since 5.1 release
- new emu manager
- installing emu -> BP -> Plugins -> Plugins -> green button
- default skin Alien - thx FatherPio
- changed keymap (dgs friendly)
- fixed timer in standby mode
- fixed incubusCamd
- many small fixes and improvements
Pozdrawiamy Polish Kathi Team
Here
I have succeed in booting the Enigma_2_9000HD_SifTeam_rel.050 from a USB harddisk.
But I cannot get the the PKT mod builds to work.
Bootings starts nicely and the wait 3min info in shown.
After that the /dev dir is builded but then the show is over with the 5min disable sequence repeating..
Any ideas?????
Log from service port:
INIT: version 2.86 booting
WAIT 3 min
Seems to be the first run - Making devices in /dev...
Mount /dev in tmpfs
Copying device nodes to /dev
Starting portmap daemon....
Sat Dec 12 20:00:00 UTC 1970
LOADING MODULES
init AVS
init stmfb
load a/v firmware
init embx
init player
init frontpanel
LOADING e2
Mounting local filesystems...
showSinglePic /boot/bootlogo.mvi
VIDEO_SELECT_SOURCE MEMORY (Success)
VIDEO_PLAY (Success)
VIDEO_CONTINUE: (Success)
VIDEO_CLEAR_BUFFER: (Success)
Cleaning /tmp /var/run /var/lock.
Hostname: cuberevo.
starting telnetd
Starting FTP server: vsftpd.
Deconfiguring network interfaces... ifdown: interface lo not configured
ifdown: interface eth0 not configured
done.
Starting DHCP client: udhcpc### adapter index 2
### adapter hardware address
udhcpc (v1.11.2) started
### vfork'ing and execle'ing /usr/share/udhcpc/default.script
### entering raw listen mode
### opening raw socket on ifindex 2
### got raw socket fd 5
### attached filter to raw socket fd 5
### bound to raw socket fd 5
### adding option 0x35
### adding option 0x3d
### adding option 0x3c
### adding option 0x39
Sending discover...
### Waiting on select...
### Got valid DHCP packet
### adding option 0x32
### adding option 0x36
Sending select for 192.168.0.20...
Lease of 192.168.0.20 obtained, lease time 268435455
route: SIOCDELRT: No such process
adding dns 192.168.0.1
### entering none listen mode
Setting up IP spoofing protection: FAILED.
Configuring network interfaces... done.
init phoenix
init internal slot card
Reloading SCI-NGsh: you need to specify whom to kill
rmmod: /var/bin/sci-ng.ko: No such file or directory
SCI-NG Driver by pacco for myIPBox.info, v1.1
[SCI-NG]: Major number 253 / First minor 0
/var/bin/sci-ng.sh: line 64: /var/bin/newcs: not found
init cifs
Trwa wykrywanie partycji swap, czekaj...
Wykryto partycje swap /dev/sda1
Setting up swapspace version 1, size = 1028123648 bytes
swapon: /dev/sda1: Invalid argument
/usr/lib/enigma2/python/Plugins/Extensions/PKT/swapstarter.sh: line 126: cannot
create /dev/vfd: No such device or address
Partycja SWAP zostala aktywowana
/var/config/rc.local: line 13: /etc/init.d/pids_prio: Input/output error
/var/config/rc.local: line 10: /usr/lib/enigma2/python/Plugins/Extensions/PKT/mo
untstarter.sh: Input/output error
/etc/init.d/rcS: line 135: /var/config/rc.user: Input/output error
starting e2->
/var/config/rc.local: line 7: /usr/lib/enigma2/python/Plugins/Extensions/PKT/emu
/etc/init.d/rcS: line 135: /usr/local/bin/enigma2: Input/output error
e2 ended <- RTV: 2
REBOOT
INIT: Switching to runlevel: 6
INIT: Sending processes the TERM signal
INIT: cannot execute "/etc/init.d/rc"
INIT: cannot execute "/sbin/sulogin"
INIT: Id "z6" respawning too fast: disabled for 5 minutes
INIT: no more processes left in this runlevel
Best regards.
Tideglo 0.5.5 AAF SummerDream 2.0
Image inforelease notes from Tideglo nightly Build)
This is our latest release: AAF Image SummerDream
AAF:
+ AAF-Panel V4.1
+ Softcam-Panel V0.21
+ Addon-Manager V1.73
+ MediaCenter
+ HD-Skin Wine Metallic
+ HD-Skin Ice Metallic
+ VFD-StandBy V0.1
+ Automount
+ Cifs,SamBa
+ Cardreader Unterst?tzung
+ NewCS Control V0.2
+ Permanent Clock
+ SetstartChannel
and much more....
Thanks go to Tideglo for the amazing basis Image and to all those that have tested and helped to bring it out.
Image builder:
megasat4000, GOst4711, Black_64, Sofatester
Betatester:
xup12, spock1111, grizzlyt, zeroone, trodonaldo, Menne.0201, Prof-Ratlos
New in Tideglo 0.5.5 AAF SummerDream 2.0
AAF-Board Viewer
How does it work ?
With this nice little plug-in you can take an active part in the board events.
You have the possibility to view either the 10 last postings, the 10 top poster,the 10 new members and 10 freely choose-able themes.You need therefore a direct connection to the Internet because all the input comes from the Board.
What isn't doing ?
The plug-in is NOT a web browser, it only loads the HTML-data from the board and it transforms it into a viewable format.
You can't answer postings, even if you have a connected keyboard!
How does it work ?
Threads:
After launching the plug-in a little welcome screen is shown for a few seconds.
Then you can see the last 10 postings (picture 1).With "OK" you are able to read them.
User-threads:
With the blue button you can choose between 10 different forums (picture 2).
With "OK" (picture 3) you select the themes, on a deeper level and another "OK" push selecting a thread it shows the posting (picture 4) . It sounds hard but it's not much different from clicking through the board.
If you want you can browse directly with the remote keys 0-9.
ID0 = key n? 0, ID1 = key n? 2....
User-thread menu:
The selection and editing of the themes and posts in the user thread is done by the "Menu" button on your remote (picture5).
There you can't put links in but you can put the board-ID.
How you obtain the board-ID :in the main menu click on the different forums, select one and click on it.In the new link you can now see the board-ID at the end.
Example: HD-Newshttp://www.aaf-Board.com/wBB2/Board.php?Boardid=189
With the green button you can save the settings. Now you can verify if your new ID's are shown in clear text in your "User-Threads" menu (picture 2).There you can see in square brackets the new board-ID.
Browsing the Postings:
In the last step the selected posting you have some keys at your proposal.
A nice feature is the right key that jumps to that latest posting.
Taskbar:
During the whole action in the left corner the current theme/posting is shown in orange to help with operations.
Buttons:
red: last 10 Postings
green: top 10 Poster
yellow: last 10 new members
blue: User-Threads
Menu: User-Threads menu, where you can save your forum settings
0-9: Direct selection of the user threads (without the need to go through the blue button menu)
Browsing your postings:
Down: browse forward (end of the list)
Up: browse back to the first post (start of the list)
Left: same as Up
Right: to the last post (end of the list)
The idea for this plug-in and programming was made by Bauernbub and was logical.Our technically prone users needed a tool to test their on-line capacity and to take part in the board happenings.With or without the need to go through a PC.
After checking the technical problems with Prinz there wasn't much in the way of coding it in python.Beta-tester "Banu" provided us with the background pictures for the skin and helped us a lot.After 25-30 hours you now have the AAF-Board Viewer at your disposal.
We wish all our dear user a much carefree experience and a better way to take part in the board events.
We wish you lots of fun, your AAF-Team.
Traduction (from german): Grizzly
http://depositfiles.com/de/files/twuxpegty
IP Box HD 9000 2xS2 tuner
Dreambox 7025-SS
Smart MX 28-IDTE IQ 2040
Sammy 9500-Sammy 9400-Sammy 9000
Triax 120 cm-Titanium 2 LNB's
thank you, helped alot
SifTeam release 0.6.0
Enigma 2 for all DGStation products:
• cuberevo-mini-fta (cuberevo-200hd)
• cuberevo-250hd (IPbox-91hd)
• cuberevo-mini (IPbox-900hd)
• cuberevo-mini2 (IPbox-910hd, cuberevo-3000hd, madtek-3000hd)
• cuberevo-2000hd
• cuberevo-9500hd (cuberevo-7000hd)
• cuberevo (IPbox-9000hd rel1 and rel2)
First boot take a little bit much more than a normal boot, so wait until you can see the bandeau bar (the one with infos on current channel) on the tv screen.
History:
release 0.6.0
• fixed positioner setup using step diseqc command
• allowed 1080p 23,97 24 25 29,97 and 30Hz as display resolution
• fixed fastforward and seeking bug in mediaplayer
• added tuxtxt configuration file and a better readable font
• fixed fast forward in timeshift and playing recordings
• fixed slow-motion bug (micro-freezes on SD channels with 4:3 content)
• supported more HDMI tv using 576 output (edid bug should be fixed, report if some tv are not working during the wizard)
• supported MHW epg
• added:
/proc/stb/video/pal_h_start
/proc/stb/video/pal_h_end
/proc/stb/video/pal_v_start
/proc/stb/video/pal_v_end
• fixed a bug on volume value and changes
• fixed some memory leak bugs
• fixed a bug with DHCP
That's all, Tideglo
Cuberevo/IP9000HD
Cuberevo Mini 2/IP910HD
Cuberevo Mini/IP900HD
Cuberevo 250HD/IP91HD
Dreambox 7025-SS
Missing link to Image for Cube revo 7000 = 9500
Index of ./Enigma2 SifTeam 0.6.0/Cuberevo 9500HD (7000HD)/
a simple question, what's the Enigema working step, i mean that how can it change the info from input to output. thank you! Because i want to get the DM500's output signal's strength, so i can control the dish automaticly according to the attitude measurements of the dish
PKT mod 7.1 Xmas Edition Tideglo rev 0.7.0
Changes made by Tideglo:
Changes made by the PKT since version 7.0 :Release 0.7.0
*fixed mute volume on channel change
*mute over SPDIF is now working
*added mp4 runtime detection
*added http mp4 streaming
*added m2ts file
*added stty
*added netstat
*added traceroute
*added grab for GUI screenshots (it does not work with live-tv screenshots)
*fixed many bugs on video drivers (don't remember all because most of drivers code were completly reviewed)
*applied better quality on video drivers (IMHO now on sd channels is really better than before)
*fixed many bugs on audio drivers (most of them on codec side)
*fixed (??) snr/agc value on tuners (especially in the sharp tuner) *fixed bug on starting network at boot
*changed bootlogo with a new default
*reorganized general driver structures
*fixed subtitles *.srt and *.ssa when there is '.' char in the file name
*fixed time in the frontpanel (now should be always get the right value, with GMT offset, also at enigma2 boot)
*fixed a bug that causes DNS to be rewritten at reboot or at network restart when dhcp is activated on the router/net (if you have dhcp activated dns will be always given by dhcp server)
*fixed a bug that make dhcp always activated
*fixed record from standby
*fixed record from deep-standby
*fixed timer bug for record scheduled events
*fixed volume bug on web-interface
*fixed menu factory reset (thanks skaman)
*fixed panscan mode on almost all possible cases *fixed audio volume on SCART wich was lower than HDMI
* Christmas theme
* changes on speed and stability
* new EMU manager 0.9.8
* new mount manager 0.7.3
* restart button added for your women with -BP-> green button
* webcam viewer plug-in added
* bootlogo selector plug-in added
* script executer plug-in added
* permanent timeshift plug-in added
* Option to play *.trp files in media player added
yours,
Polish Kathi Team
Caution: it is illegal to use this software to watch paytv without a legal subscription and the abuse could lead to imprisonment penalties up to three years !
IPBox 9000 HD
IPBox 910 HD
IPBox 900 HD
IPBox 91 HD
Dreambox 7025-SS
AAF Wintertime Image
IPBOX 9xxx HD/Vizyon 8xxx HD
Image info
GIT Enigma2 AAF Winter Image (Image 15) Changelog:
Changelog since the last public release:
Team Ducktales (only IP-Box):
+ gotosleep changed as fp_control
+ MP3 Playback more stable
+ DTS Fix
+ Kernel optimisation
AAF Panel 7.9
MediaCenter
AAF
+ AAF Panel 7.9 (added VideoTune | several fixes and updates)
+ Volume Adjust (menu -> settings -> VolumeAdjust)
+ Cleanup Wizard (menu -> settings -> system ->...)
+ Crashlog Wizard (menu -> settings -> system ->...)
+ MediaCenter (IMDb Support | new Videoplayer Filelist | WeatherPlugin | WebRadioFS)
+ miniuboot r1.3 update (for lzma compressed kernel, better compression and a little more speed)
+ repairmodus (when error or bootloop)
+ usbspeed (test usb storage speed)
+ mixed lzma/zlib compression for /var (better compression and a little more speed)
+ usb-storage.usbwait123 kernel parameter (setting the boot sequence)
+ ntfs read/write support (you can activate this in aaf panel)
+ much fixes in samba server
+ only boot E2 on error (you can activate this in aaf panel)
+ new onlineflash tool (with verify and tv output)
+ new system layout (for more /var free)
+ partition load for problem storages (you can activate this in aaf panel)
+ some fixes in ramswap
+ wget, fsck, mkfs (percentage display on vfd and tv)
+ much other fixes...
Known problems:
- Sometimes after switching sound dropouts
(switching manually the channel or the sound helps)
- Timebug: you need a working Internet connection.
Rebootvideo
Shutdown Video
Thanks go to the sh4-receiver-developer for the amazing orig. Image and all that have helped to create and test it.
Your AAF Team
AAF Wintertime Image 9000 Flash:
RapidShare: 1-CLICK Web hosting - Easy Filehosting
AAF Wintertime Image 9000 USB:
AAF Wintertime Image 910 Flash:
AAF Wintertime Image 910 USB:
AAF Wintertime Image 900 Flash:
AAF Wintertime Image 900 USB:
AAF Wintertime Image 91 Flash:
AAF Wintertime Image 91 USB:
Dreambox 7025-SS
NLB8478 for 910 and 900
NLB8478-910-v1.2 for IP box 910
and for NLB8478mini_v1.2 for IP box 900Code:http://rapidshare.com/files/168818168/nlb8478-910-v1.2.rar
Code:http://rapidshare.com/files/168821186/nlb8478mini-v1.2.rar
AbCom IPBox9 Series / CubeRevo nlb image Unofficial Custom releaseCode:Features of NLB Image - delay option in nlb panel for problems with newcs init card, such as nagra3 cards. - Germans should set delay to about 20 seconds, so it will decode at bootup - without need to restart cam. - NFS mount as replacement for internal HDD (for SD recording only) - HD/MPEG4 recording works too, but will studder as MPEG4 can be upto 20Mbyte/second and with 100Mbit network card, it will never work good. - Onscreen panel for stop/start of most features found in webif. - Internet update function for webif and panel for now. - Customized startup, faster load times - Added support for external usb serial port (PL2303 USB-Serial) - Added binary utils - ssh / scp / sftp (client tools) - fw_printenv / fw_setenv (uboot environment see/change) - strace - cron daemon - alternative thttp daemon (not used) - Emus included (in /data folder, Read-Only) new updates should be placed in /var/bin .. (see name in [] ) - [newcs] newcs 1.62 (newest 23.10.2008) - [incubusCamd.sh4] incubus 0.5 (newest 22.10.2008) (DISABLE TIMESHIFT TO MAKE THIS EMU WORK!) - [mgcamd130] mgcamd 1.30 for nordic viasat users - [mgcamd] mgcamd 1.30d ( use 1.30 if you are viasat nordic user, for faster channel switching) - mpcs 0.9d - [mbox.sh40] mbox II 0.4 Build 005 (3.10.2008) - [evocamd] evocamd - all key files should be put into /var/keys folder. - Samba (Windows networking sharing) - ftp / telnet / ssh server - terminfo for top (primarily) - USB multiboot (see below for details on how to use it) - supports all_noboot images too.. (except AbCom image) - WebIf (details below) - Bootscript for loading at every startup - /var/S59_bootscript and remember "# chmod 755" on script ********************* NFS Media setup howto --------------------- Its not possible to configure a NFS mount in dgs application as DGS do not support NFS, but in background this is handled so do not worry about choosing CIFS setup in mount manager. the line in your /var/mount_manager_fstab should look similar to this. cifs /mnt/nfs 10.1.12.100 /var/nfsmediashare dexter dexter NLBshare Disconnected IMPORTANT: current release has one requirement "rule".. part of NFS sharelocation needs to include nfsmediashare , so your share can be /media/nfsmediashare or /movies/nfsmediashare or similar.... just remember to include that name in share. after you configured this, you also need to enable in webif, and choose IP9000 -> Change NFS/HDD media. you can edit the file and reboot box or you can configure in dgs application, but do not press "connect", it will not work like this. After you enabled it in webif, and configured the line in your mount manager, you can reboot and at next boot you got /media mounted from your NFS server. For this wondering why CIFS is not supported, its because CIFS do not support directio and also speed of CIFS is worse than NFS. ***** WebIf ----- ----- The webif is your control center of the NLB mod image. Default login is: root and password: relook If you need to update access table for ip addresses allowed to access webif, please edit the /var/etc/httpd.conf You find a line here ie. A: 192.168. Enter your network segment here, example A: 172.24. or a specific public ip A: 212.242.1.12 Save file, and reboot box, and you got access to the webif. - System information * Processes - List current applications running on IPBox * Change SWAP HDD - Activate Swap or disable it. * CPU Info - get IPBox cpu info details * System Boot information - output of "dmesg" startup of box. can be used even if your box shows "PANIC". - System options * restart samba - restart windows sharing service. * Samba status - Activate or stop samba/windows sharing services * Change HDD filesystem - Choose between ext2/ext3 or existing. ext2 filesystem will run FSCK (filesystem checks) ext3 filesystem skips FSCK * telnet status - Activate or stop telnet service * ssh status - Activate or stop ssh service * ftp status - Activate or stop ftp service * Restart box - Reboot your box - Firmware options * Upgrade FW - Upgrade firmware from img file in /var or /media folder. transfer .img file to /var or /media folder and select this option to upgrade firmware. * Multiboot - Read below for details - USB options * SWAP - activate or disable swap on USB key * Format USB - format a usb pendrive/stick for use with box - and for multiboot setup * NOTE: USB Stick will be mounted on IP900 as HDD if above 2GB And this means it cannot be formatted in webif on ip900. * Mount USB - mount a USB stick on box, to access files on it location: /mnt/usb/usb0 * Copy /var - make backup of /var to your usb stick * backup db.dat to usb - copy your db.dat file to your usb stick * restore db.dat from usb - restore db.dat (will be named db.dat.edited) requires reboot to take effect. * List contents of usb - list contents of usb stick, if mounted. - IPBox options * HDD/NFS media folder change - NOT ENABLED AS OF THIS WRITING! * Change Fan - enable/disable fan in Ipbox. * Show time in led - activate Time in VFD display. * Change led - Change VFD brightness (0-7) * stop sbox at next boot - will disable start of "satbox" application at next boot (debug) * Assign color button - Read/Yellow/Green buttons can be assigned functions most options above + more described below here. WideScreen - stretch tv picture on TV's that do not do it automatically. ecm info - show current ecm info on tv hdd temp - Show HDD temperature on tv display restart cam - says what it does stop cam - -- !! -- Soft updater - run your /var/bin/soft script * Change skin - Change the look of your menus in DGStation satbox application. * Skin: Crash Blue * Skin: Crash Grey * Skin: Crash DeepBlue * display HDD temp - show current temperature of HDD - Emu * Change mbox status - Stop/start mbox at next boot. * Remember to use "change emu" also to choose this one * Change mgcamd status - Stop/start mgcamd at next boot. * Remember to use "change emu" also to choose this one * Change emu - Select between evocamd / mgcamd / mbox , to be automatically startup at boot. * Stop Emu - Stop running emu. * Restart Emu - Restart running emu. * Change newcs status - choose to stop or start newcs at bootup. * Change newcs config - Choose between both/upper/lower newcs default config - this will overwrite your existing configuration. * ECM - Show current ECM of provider. * Mgcamd shares - show current connections * Card stats - mgcamd status * Info about cards - if gbox peer enabled, shows current list of cards. - Keys update * Sxxxx.Kxx Update runs your /var/bin/soft script ************************** EMU DEFAULT CONFIGURATIONS -------------------------- -------------------------- mgcamd included is a default config to run with newcs and use internal card readers (activated default) originally tested with Viasat and CanalDigital cards. mbox included is a default config to run with newcs and use internal card readers (activated default) Tested with CanalDigital card. Now includes 32100.list, 32101.list with default all channel opened. evocam is included, but there are no defaults for anything configured! incubusCamd is included, but defaults are still in testing and this is a beta release of cam. ************* USB MULTIBOOT ------------- ------------- - Multiboot feature gives you the option to boot off a usb pendrive/stick, so you can more easily place as many files you wish into the root file system, with the only limit of the usb filesystem size. - It also uses the USB pen for /var storage, so each image will have its own setup. - Removing the usb pen, will cause box to boot flash image. - USB pen should be formatted in webif, before use - other USB pen cannot be used/formatted in webif, when you are running multiboot. Instructions for usb multiboot ------------------------------ - Format a usb pen in webif (USB Options - Format USB) (old formatted usb sticks from 8022 and down needs reformatting) if used in DGS box during mp3 playback or photo album, it will not work. - Wait for an OK from formatting (takes 30-60 seconds depending on size) - Placing firmware on usb pen procedure - * For /media folder - with ftp copy an .img file to the /media folder - Only DGS / SifTeam / NLB images will work. - * For /mnt/usb/usb0 folder - mount usb pen in webif (USB options - Mount USB) - select Firmware Options - Multiboot - in field "Enter name ...." write a suitable name for image - in "Choose file to put on usb" select image to put on usb - in front of img file you can see location of file. - Press "extract" to extract image to usb. NOTE: IF NO USB PEN IS INSERTED YOU DO NOT HAVE OPTION TO INSTALL IMAGES! OR FORMATTED CORRECTLY, ie. Windows formatted pen will NOT work. - when finished (takes 2-3 minutes), reselect "Firmware Options - Multiboot" - In bottom "Select USB bootimage to use" you can now see your image. ? if it is not shown and extract failed, make sure your usb was formatted with a unix fs, ie. using format usb in webif. - You can choose to "Change" and mark which image to load at next boot or - You can choose to "Delete" firmwareimage from usb. - Selecting "Flash boot" will make box boot your flash / disable usb boot. - Reboot box to start usb firmware.Code:added: NFS mount replacement for HDD SD media recording folder * --------: - can be enabled disabled under IP9000 -> change NFS/HDD media in webif. * - Thanks to DGS for assistance on kernel fix. * - HD Recordings works too, but will studder! so you are warned. * fix: NFS mount on boxes without internal hdd. * fix: Slow NFS mount fix (thanks to semack for the help). * added: - delay option in panel for Nagra3 cards. * added: - Germans with nagra card should use 20 seconds and it decodes at bootup * added: ushare for sharing through UPnP protocol (like to PS3) Thanks to Kneubi * -----: enable/disable/restart in Webif->system options * added: Option to run boot scripts from /var/etc in hotfix situation. * plugins: bitrate 0.0.2 and favpip 0.7 . * updated: newcs.xml added boxkey code to support German *** cards. * updated: NL language files (Gman2006)Code:http://rapidshare.com/files/172469456/usb_all_noboot_nlb8611-v1.21.rar
