Page 5 of 5 FirstFirst 12345
Results 61 to 70 of 70
Thread: Enigma Images
  1. #61
    Official ABcom r8630 for IPBox9000HD
    AB r8630_151208_change log
    Bug Fixed :
    - PVR trick/record length bug
    - Fast scan bugs
    - crash problem When schedule recording
    - Nova HD EPG fixed
    - crash problem after press EPG button in Bulgarian menu
    Changed/improved :
    - add DVB and TTX subtitle support
    - Change Date format(dd.mm.yyyy)
    - add support for DreCam - You need installed "addon_DreCam_support...."
    - improved LAN connection speed (now is speedy)
    - for 9000HD : add post descramble option with CAM?s
    You can record scrambled channel and descramble before playback:
    Go to record files list, select scrambled record, press Record button, select CAM with card
    for descramble and press OK. STB create new descrambled file.
    - support youth protectioon
    - support nfs mount recording
    . remove access to /media/
    . mount remote directory to /media
    . mount -o nolock,soft IPIRECTORY /media/
    - display video resolution in info banner
    - upgrade Finnish, Russian, Polish, Bulgarian, Czech and Slovak languages
    - Support HDMI with compressed Dolby digital audio
    - Add Front scroll function when channel name is long.
    - When schedule recording, remove timeshift buffer.
    - new AB setting for Astra 19.2, HotBird 13 and Astra 23.5
    - installed plugins: mail, weather, bitrate , tetris, pong, sudoku, favpip
    instalation
    copy "addon_version-9000HD_sh4.ipk" to /tmp
    connect to box with webinterface ( write IP adress of your box to internet browser)
    use login/password : root/ipbox
    go to menu addons
    select manual
    press install
    wait for STB reboot
    Abcom Image v8630 for IP box9000
    http://rapidshare.com/files/173975135/Abcom_official_image_v8630_for_IP9000.rar
    Drecam addon
    http://rapidshare.com/files/173973017/dreCam_version-9000HD_sh4.rar
    Drecam and Mgcamd 1.31 addon for IPbox9000
    http://rapidshare.com/files/173975776/DreCam_addon_with_mgcamd_1.31_version-9000HD_sh4.rar
  2. #62
    NeutrinoHD 0.2.0 Nightly Build 91hd und VIZYON 800HD
    http://www.2shared.com/file/10674833/ca7c7970/release_020_cuberevo-250hd_fla.html
  3. #63
    PGI v0.5, H?llenbrut - 91HD
    12.01.2010
    | PGI v0.5, H?llenbrut |
    Vielen Dank an uncle.f f?r die Mitarbeit an dieser Release!
    Features
    - Basierend auf DGS 11577
    - HD Sender funktionieren ruckelfrei, dank gefixter Treiber.
    - newcs, mgcamd-1.33, incubus und mbox sind eingebaut, allerdings sind nur newcs und mgcamd vorkonfiguriert.
    - Aktuelles stabiles busybox 1.15.3 eingebaut.
    Die shell Kommandos funktionieren damit alle, und die shell hat eine permanente history.
    Ausserdem ist noch der Texteditor nano f?r die Konsole beigef?gt.
    - Eigener Kartentreiber.
    - Streaming Player von sbox gefixt (Server part):
    Funktioniert jetzt auch mit verschl?sselten Kan?len, Qualit?t des Streams besser.
    - Bootzeit verk?rzt
    - Farbtasten mit Skripten belegt, um emus zu wechseln (siehe weiter unten)
    - und weitere kleine ?nderungen ...
    ?nderungen
    Allgemein:
    - NFS share kann als Festplatten ersatz benutzt werden
    - Support f?r DRE-Cam's
    - Hinzugef?gt: mg_launcher f?r Leute die mit dem normalen mgcamd probleme haben.
    - Update: WebIf 1.5
    - Update: Busybox 1.15.3
    - Update: Sqlite 3.6.21
    - Update: e2fsprogs 1.41.9
    sbox:
    - Fix: auto mounting funktioniert wieder
    - Fix: connected und disconnected werden in der mount_manager_fstab nicht mehr ?bersetzt
    - Fix: Der EPG Parser bleibt nicht mehr h?ngen auf Kan?len mit nur now&next information (danke an kneubi)
    - Funktion von PgUp/Down buttons und Buttons in den Kanal- und Favoritenlisten getauscht
    - Timeshift kann mit dem Stop button beendet werden
    - Aufnahmewiedergabe kann nun auch direkt in der Dateiliste gestoppt werden
    - Normaler Lautst?rke balken wird im Videoplayer angezeigt
    - Passwortabfragen k?nnen nun generell per Option An- oder Abgeschalten werden (Im Men? Kindersicherung)
    - Die per Kanal abgespeicherten Lautst?rken werden beim umschalten sofort angewendet
    - In der Kanalliste kann mit der blauen Taste Alphabetisch sortiert werden, anstatt zu den Favoriten zu springen.
    Die Favoriten sind weiterhin ?ber die FAV Taste erreichbar.
    - Multicast im Streaming Player funktioniert wieder
    - Unicast Option im Streaming Player entfernt. Wer nur unicast braucht sollte lieber WebTV im Webif verwenden.
    - WWW taste auf der Fb kann ein skript zugewiesen werden, /var/bin/www.sh
    - Neuer Men?punkt Wettervorhersage im Hauptmen?
    - OSD Screenshots im WebIf funktionieren jetzt
    Konfiguration
    Die Imagespezifischen Konfigurationen liegen in /var/etc.
    boot_services.cfg
    Hier wird festgelegt welche Dienste beim Boot gestartet werden.
    Dienste sind z.b. samba, nfs, newcs, etc.
    Ausserdem werden hier der skin und der standard emu eingestellt.
    my.zooms
    Liste von zooms die verf?gbar sind.
    Wird vom Gr?nen Knopf benutzt.
    my.ethaddr
    Wenn die Box abst?rzt oder nicht richtig heruntergefahren wird, dann ?ndert sich beim n?chsten boot die mac Adresse
    der Netzwerkkarte.
    In dieser Datei kann man eine feste mac adresse eintragen, die immer erhalten bleibt, auch nach abst?rzen.
    Beispiel f?r den Inhalt: 12:BB:CD
    Man kann nur die letzten drei stellen der Adresse ?ndern, die ersten drei sind immer 00:13:18.
    Existiert die Datei nicht, dann wird automatisch die aktuelle Adresse verwendet.
    nonstandard_encoding
    Mit dem Skript scrplg-fan-disable.sh kann der L?fter bei Boxen ohne HDD dauerhaft abgeschaltet werden.
    Dazu das Skript im Script plugin ausf?hren.
    Funktionen auf Farbtasten
    Rot => Favpip
    Gelb => Emu neustarten
    Gr?n => Zoommodus wechseln.
    Viel Spass,
    pacco
    http://hotfile.com/dl/23911664/c8466aa/PGI-91-v0.5.zip.html
  4. #64
    PGI v0.5, H?llenbrut - 900HD
    Features
    - Bootzeit verk?rzt
    ?nderungen
    Allgemein:
    - Update: WebIf 1.5
    sbox:
    Konfiguration
    boot_services.cfg
    my.zooms
    my.ethaddr
    der Netzwerkkarte.
    Rot => Favpip
    Viel Spass,
    pacco
    http://hotfile.com/dl/23914409/457df1d/PGI-900-v0.5.zip.html
  5. #65
    PGI v0.5, H?llenbrut - 9000HD
    Features
    - Bootzeit verk?rzt
    ?nderungen
    Allgemein:
    - Update: WebIf 1.5
    sbox:
    Konfiguration
    boot_services.cfg
    my.zooms
    my.ethaddr
    der Netzwerkkarte.
    Rot => Favpip
    Viel Spass,
    pacco
    http://hotfile.com/dl/23915900/3f6ac52/PGI-9000-v0.5.zip.html
  6. #66
    PGI v0.5, H?llenbrut - 910HD
    Features
    - Bootzeit verk?rzt
    ?nderungen
    Allgemein:
    - Update: WebIf 1.5
    sbox:
    Konfiguration
    boot_services.cfg
    my.zooms
    my.ethaddr
    der Netzwerkkarte.
    Rot => Favpip
    Viel Spass,
    pacco
    http://www.2shared.com/file/10624812/47ada414/PGI-910-v05.html
  7. #67
    PGI v0.5, H?llenbrut - 7000HD
    Features
    - Bootzeit verk?rzt
    ?nderungen
    Allgemein:
    - Update: WebIf 1.5
    sbox:
    Konfiguration
    boot_services.cfg
    my.zooms
    my.ethaddr
    der Netzwerkkarte.
    Rot => Favpip
    Viel Spass,
    pacco
    http://www.2shared.com/file/10625278/4409083f/PGI-7000-v05.html
  8. #68
    aftermath's Avatar
    Mar 2008
    Default PKT E2 8.9.1 based on Tideglo`s version
    10.03.2010
    What is new
    -Roumanian language(superonic,costel_mbc,neutrin,otheitis,cip y_1982,run canion)
    -fixed newcs start.
    Thanks Lareq and the PKT team
    DOWNLOAD IMAGE 43 MB
    get it here
    follow this thread http://www.digital-kaos.co.uk/forums...30/#post394928 to get crossEPG working ( beware when scanning EPG it takes a very long time, so dont think box has crashed as it will eventualy finish its job).
  9. #69
    Member grizzlyt's Avatar
    Oct 2008
    Default AAF WM Image IPBOX HD
    Changes since the Spirit of Spring image:
    GIT rev1057
    + Fix freesat EPG
    + Stream Proxy improved
    + Fix kernel STM22
    + Based now up to 95% on the Git
    + Szap Kernel
    + Git Player2
    + Enigma2 06/2010
    + Only tuner, front panel and CI driver from Tideglo 0.96
    - Optimization is still in beta
    AAF M3465
    + szap (TV screen during the boot process is already possible in under 30 seconds)
    + szaplong for virtually seamless transition into E2
    + progress bar on display during boot (optional)
    + Fixed text buttons in MC
    + FullHD icons in the info bar in 1080i and HD Ready channel icons in 720p resolutions.
    szap Info:
    szap l?sst sich unter
    -> Men? -> AAF Panel -> Einstellungen -> Szap Config
    - szap - Ja
    aktivieren
    szaplong:
    ist eine Zusatzfunktion die den in szap gew?hlten Kanal mit dem E2 Kanal synchronisiert so das ein nahezu nahtloser ?bergang m?glich ist.
    szap_frontend:
    0 benutze Tuner1
    1 benutze Tuner2
    Filehosting 9000 HD Flash
    9000 HD Full USB
    9000 HD USB
    910 HD Flash
    910 HD Full USB
    910 HD USB
    900 HD Flash
    900 HD Full USB
    900 HD USB
    91 HD Flash
    91 HD Full USB
    91 HD USB
    IP Box HD 9000 2xS2 tuner
    Dreambox 7025-SS
    Smart MX 28-IDTE IQ 2040
    Sammy 9500-Sammy 9400-Sammy 9000
    Triax 120 cm-Titanium 2 LNB's
  10. #70
    Oct 2008
    Default ACT E2 096 rev 1 mod Tideglo 0.9.6 usb
    Changelog Tideglo release 0.9.6 :
    * fixed many bugs with multidescrambling (now you should be able to descramble 2 channels on different tuners)
    * fixed some player memory fault
    * update Enigma2 CVS to 25/05/2010
    Changelog 0.9.6 ACTeam :
    * removed ACTemumager changed by friendlyuse emumanager
    * added in emumanager incubus 100,110,116
    * channellist can be download in actpanel -subtitles selection merged into audio selection=yellow button
    * added start/stop services for drobbear,Crontab
    * fixed playback recorded files(thanx tideglo)
    * default skin is infinity -added 3 other skins with caminfo,caid,cryptinfo
    * changed spinner,add restart logo
    * fixed cam start at full reboot
    * small fixes and enhanced some panels
    * extra plugins:
    * crossepg
    * divxplayer(plays only divx files)
    * glass sysinfo -enhanced epg
    * permanent recording
    thanx to Tideglo for the nightly build image and the betatesters
    Downloads:
    CubeRevo-250hd/91HD
    CubeRevo-mini/900HD
    CubeRevo-mini2/910HD
    CubeRevo/9000HD
    Known bugs:
    subtitle selection may crash if there no subs(empty list) to chose
    if you find any other bugs please report it so that the team can fix that in the next release
    with best regards from the Satboxteam former ACT Team
    Dreambox 7025-SS
