Page 1 of 4 1234 LastLast
Results 1 to 15 of 70
Thread: Enigma Images
Hybrid View
    V.I.P. Member sotiris70's Avatar
    Nov 2008
    Default Enigma Images
    ENIGMA 2 for ipbox HD/cuberevo SIFTeam:
    First boot take a little bit much more than a normal boot, so wait until you can see the bandeau bar (the one with infos on current channel) on the tv screen.
    Default settings are for single tuner on HotBird sat. (you can change them in the menu)
    WARNING: Do not forget to change your DNS configuration (if you want to use the decoder on the net). The DNS configuration could only be made by editing manually the file "/etc/resolv.conf"
    HISTORY:
    release 0.1.0(beta):
    This is the first public release, it's released as a beta version, probably it has many and many bugs, but to fix and to discover them I need all your help, so I decided to make it public
    This version does not support:
    - card reader
    - DVB-T, DVB-C, DVB-S tuners
    - twin tuner
    Enjoy it! Tideglo
    ABOUT ENIGMA 2 for ipbox9000/900/910/cuberevo/cuberevo-mini:
    This is an adaption of Enigma 2 for the DGStation's High Definition boxes.
    I want to thank these people:
    Team DuckTales: for helping me on finding really many bugs and to helping me on make Enigma2 like it is now.
    zbigzbig20: for default bootlogo
    Spaeleus: for Italian translation
    SIFTeam: this is my place, with all my friends that i like really to chat with!!!! (I LOVE YOU GUYS)
    I want also to thank two special friends:
    genge: for be the best betatester of ever!!!!! (really a ball breaker but also a good friend )
    PhotosOfGhosts: for helping me on finding, studying and solving bugs
    Regards, Tideglo
    HOW TO INSTALL:
    To test this enigma2 image you need a running nfs server and a serial & network
    connection to the receiver.
    You need uboot 1.3.1 or higher to run e2 (never tested with lower versions)
    Do this only if you want to use nfs-server otherwise go to point 3:
    1. extract the tgz file on the server and set the directory in /etc/exports
    for example:
    /root/Desktop/root 192.168.1.0/255.255.255.0(rw,no_root_squash,sync,no_subtree_ch eck)
    where 192.168.1.0 is your net base-address and 255.255.255.0 is your netmask
    2. restart nfs server
    3. connect via serial console with an hyperterminal connection to the receiver (I suggest you to use putty, it's freeware, and configure it to use a 115200 serial connection)
    4. turn on the receiver and hit ctr+z in serial console
    you should see the following prompt:
    cuberevo>
    5. customize the following settings to your network environment and type them into the
    serial console:
    setenv menu_1 'setenv ipaddr 192.168.1.5;setenv serverip 192.168.1.6;setenv gateway 192.168.1.1;setenv netmask 255.255.255.0;setenv bootargs "console=ttyAS1,115200 panic=3 bigphysarea=10240 root=/dev/nfs nfsroot=/root/Desktop/root rw rootpath=/root/Desktop/root ip=$ipaddr:$serverip:$gateway:$netmask mem=128m coprocessor_mem=4m@0x10000000,4m@0x10400000 init=/bin/devinit";setenv bootcmd "nfs a5ff0000 192.168.1.6:/root/Desktop/root/boot/uImage;bootm a5ff0000";saveenv;boot'
    setenv menu_2 'setenv ipaddr 192.168.1.5;setenv serverip 192.168.1.6;setenv gateway 192.168.1.1;setenv netmask 255.255.255.0;setenv bootusb "run bootargsusb;usb reset;ext2load usb 0:1 a5ff0000 boot/uImage;bootm a5ff0000";setenv bootargsusb "setenv bootargs console=ttyAS1,115200 panic=3 bigphysarea=10240 root=/dev/sda1 rw rootdelay=10 init=/bin/devinit ip=$ipaddr:$serverip:$gateway:$netmask mem=128m coprocessor_mem=4m@0x10000000,4m@0x10400000";seten v bootcmd "run bootusb";saveenv;boot'
    setenv menu_3 'setenv ipaddr 192.168.1.5;setenv serverip 192.168.1.6;setenv gateway 192.168.1.1;setenv netmask 255.255.255.0;setenv bootusb "run bootargsusb;usb reset;ext2load usb 0:1 a5ff0000 boot/uImage;bootm a5ff0000";setenv bootargsusb "setenv bootargs console=ttyAS1,115200 panic=3 bigphysarea=10240 root=/dev/sdb1 rw rootdelay=10 init=/bin/devinit ip=$ipaddr:$serverip:$gateway:$netmask mem=128m coprocessor_mem=4m@0x10000000,4m@0x10400000";seten v bootcmd "run bootusb";saveenv;boot'
    setenv menu_4 'setenv ipaddr 192.168.1.5;setenv serverip 192.168.1.6;setenv gateway 192.168.1.1;setenv netmask 255.255.255.0;setenv bootargs "console=ttyAS1,115200 panic=3 root=/dev/mtdblock3 bigphysarea=1500 ip=$ipaddr:$serverip:$gateway:$netmask quiet";setenv bootcmd "bootm a0060000";saveenv;boot'
    saveenv
    remember to customize where /root/Desktop/root is the directory you added to /etc/exports and ipaddr is the ip of your decoder, serverip is the ip of your nfs-server, gateway is your gateway ip, netmask is the mask of your home-net
    6. now you can restart your decoder and press the relative remote controller's button for 5 seconds to start the image you want:
    Press Button 1: start your image using nfs-server
    Press Button 2: start your image using usb pendrive if you don't have a SATA hdd
    Press Button 3: start your image using usb pendrive if you have a SATA hdd
    Press Button 4: start your original flash image in the decoder (DGStation's original firmwares and images based on them)
    That operation is necessary only the first time you want to change your boot commands. You don't need to press all the time you reboot the decoder a button to select wich image to start, simply do that only if you want to change to e2 nfs from usb, or from original images.
    That's all, Tideglo
    aftermath's Avatar
    Mar 2008
    Thats good news sotiris.
    now we have a chance that CCcam will be made available for the IPbox.
    Nov 2008
    Quote Originally Posted by aftermath View Post
    Its not sure now we have enigma2 for Ipbox HD, that we will have CCcam.It all depends at Cccam team if they what to make it work on Ipbox HD.
    Good that with this first release of Enigma2_Sifteam, the incubus is working.
    Congratulations to the guys of Sifteam, and to those who took part to the develpment of this first Enigma2 release.
    The first step has been made.
    aftermath's Avatar
    Mar 2008
    Thats great news Sotiris, do i just use my existing incubus.cfg and replace the the one on the enigma2 image ?
    if so is it kept in the same directory in the Enigma image.
    also will you be working on the UK EPG on this one ?
    V.I.P. Member satman's Avatar
    Jun 2008
    Never Never Land
    He wont be working on the epg yet as enigma2 doesnt yet support dvb-c tuner guys... ( e2 current only support ONE dvb-s2 tuner )
    but in future looks good..
    @aftermath,,, you have incubus to connect to cccam and e2 version
    but do note both are still very beta,, i.e enigma2 and incubus,, but a good sign of things to come,,
    and high kudos to SIF team,,
    boom!
    Nov 2008
    Script incubus Camd_e2 for Sifteam Enigma2
    I attach script file to run incubuscamd on sifteam enigma2 firmware and for users that have hard drive installed set stand by to 5 minutes
    Make backup copy of rcS file in /etc/int.d/
    you must put all file in the directory like in my zip file.
    You must set chmod 755 attributes for these files:
    in var/bin
    incubus_camd.sh
    incubusCamd.sh4_e2
    in etc/init.d
    rcS
    To run the incubus on sifteam enigma2, go telnet and write:
    /var/bin/incubusCamd.sh4_e2 &
    thanks to genge
    aftermath's Avatar
    Mar 2008
    Default CIe2T enigma2 ver.1.0
    Enigma2 Team Ducktales Build rev439 CIe2T MOD 1.0
    Filesize = 35mb
    Basis Team Ducktales Build rev439 from 07.11.2008
    Team Ducktales:
    + divX test changes
    + portmap start with boot
    + code optimizings
    + iopriopatch
    + Python update on 2.6 +patch
    + HDMI and YUV control separately
    + module handling changes
    + right/left in EPG fixed
    AAF:
    + AddonManager 0.43
    + WebIF on port 80 set for simple use
    + tar fixed
    + new AAF Glacial Skin
    + new AAF Softcam panel V0.7
    + Softcam announcement in the Skin (/switch offable)
    + VFD brightness attitude via OSD
    + Sherlock Plugin on red key in the AAF menu
    + optics adjustments
    + gear wheels by satellite replaces
    + spinner selector (several waiting animation to the selection)
    + NFS Autoswap
    - Videomode do not put back to rev210 any longer necessarily
    Thanks to Ducktales team for the super base image.
    The whole team CIe2T for a great fixes of stability,blue pannel,addons and all the other "invisible" stuff...
    for server support,and for great hospitality...
    Miro(matrix10) for Rihanna skins;We hope for a great future collaboration...
    Cronicus for great spinners and logos.
    And thx to betatesters mstevanic,svedba,wolf1976...
    We hope that you gonna like it!!!
    << --- mm_@ngel & dd_evil@666--- ****>
    http://rapidshare.com/files/171405590/CIe2T_ALL.tar.gz
    DK Veteran catseye's Avatar
    Nov 2008
    England
    Thanks to Aftermath & the teams involved for this
    The $64'000 question is...
    Can this image be loaded directly into the flash or via the previous method of loading Enigma 2 onto IP box/ Cuberevo
    Many Thanks
    aftermath's Avatar
    Mar 2008
    Installs the same as first E2 image, but takes a lot longer to flask especially the last telnet command.
    It only has Mbox installed , and the blue Panel is in Polish.
    you need to put in an old satellites.xml file in as this only has 2 pre defined.
    But it looks good, plenty new stuff
    there is a small bug when you go into the cam panel, when you try to come out of it, you get the green death screen. and box reboots.
    The scanning is a lot faster on this image.
    aftermath's Avatar
    Mar 2008
    To get the Blue Panel in English.
    blue panel - blue button
    choose: Upravitelj dodacima
    choose: Upravitelj Download-a
    choose: PanelLang
    choose: CIe2T_ENG
    in there ,
    downloads,
    emu.
    There is also camd.01, kbox, incubuscam, camd3
    This is not a totaly new E2 image, it is a re vamped sifteam one by CIe2T, it is a much more stable one than original one, and has many more plugins.
  11. #11
    Dec 2008
    Is it possible with this image on a USB stick to change the box IP after installation? I have got dual boot working well with the latest SIF image in flash and used the 9000-usb_config_welcome.img image from SIF to boot engigma but that method does not allow changing the Enigma IP
  12. #12
    aftermath's Avatar
    Mar 2008
    i am afraid you will have to change the uboot loader to the different IP address.
  13. #13
    Dec 2008
    Thanks aftermath, have tried editing 9000-usb_config_welcome.img with notepad and insering the correct IP,s uploading fails with a CRC fail. If I use fw_setenv commands they also fail with a CRC fail. Any ideas how to progress?
  14. #14
    aftermath's Avatar
    Mar 2008
    Default Enigma2 SifTeam Flash Version 0.1.0 for 9000-900-910
    This release is based on the same version of usb stick (0.1.0) but working on flash.
    In this first beta var space is very very little because we have used only jffs2 compression method,but we want to release for people that have problems to install it on usb stick.
    to allow users to modify some files (that with jffs2+squashfs are in read only) such as var/etc/init.d/rcS to start some scripts,like cam,hdparm etc etc.
    If you want to recover some var space delete picon dir and second skin "Vader".
    I think that someone make a little script to move var on usb in a simple way
    There is a display bug for ipbox900hd release (we will fix in the next release)
    To flash your stb use: rename firmware in usb_update.img and use usb stick with standard flash method . For ipbox9000 you can also use Flashtools and usb cable
    set bootargs in this way:
    setenv then press enter
    then
    setenv bootargs console=ttyAS1,115200 panic=3 root=/dev/mtdblock3 rootfstype=jffs2 rw bigphysarea=10240 ip=192.168.1.150:192.168.1.111:192.168.1.1:255.255 .255.0 mem=128m coprocessor_mem=4m@0x10000000,4m@0x10400000
    192.168.1.150 is my lan ip (decoder)
    192.168.1.111 is my serveripaddress (you can set standard value,it's not important)
    192.168.1.1 is my gateway ip (my router)
    255.255.255.0 this is netmask
    IPbox9000HD
    http://rapidshare.com/files/172513726/usb_enigma2_9000hd.rar
    IPbox910HD
    http://rapidshare.com/files/172518623/usb_enigma2_910hd.rar
    IPbox900HD
    http://rapidshare.com/files/172521941/usb_enigma2_900hd.rar
    How To Install English Panel.
    First by ftp enter to var/ and copy there all content from unpacked archive var/ from pc after copy give chmod (attribute) 755 for all files inside folders. Now by ftp copy folder "Fantactic" to: /usr/lib/enigma2/python/Plugins/Extensions/ After this give all files inside "Fantactic" folder chmod 755. Now just restart E2 (restart gui) and have fun with fully translated PKT panel under Blue Button.
    http://rapidshare.com/files/172522839/PKT_Panel_v3_ENG.zip
  15. #15
    Dec 2008
    Red face how long will take for startup
    I have download it and know it reach download module and stop
    I need to know normally how longs it take to start.
