DPF is off
garagetech (14th April, 2014)
Whats the bhp from the file I've posted ? Has it been remapped babos
i think 140hp
that engine can be without dpf from factory.
Its had a recon engine but i about dpf it was removed later by someone
the dpf has been removed with volta i believe, can someone remove dpf manually
Dpf was removed byt not correctly here is the corrected file and is original not mod
IF YOU THINK IT'S EXPENCIVE TO HIRE A PROFESSIONAL,WAIT UNTIL YOU HIRE AN AMATEUR
garagetech (16th April, 2014)
