Results 1 to 9 of 9
Thread: OPCOM problem
    lkjubaking's Avatar
    Feb 2013
    Serbia
    Default OPCOM problem
    I have problem with my OPCOM clon
    Number of interfaces: 1
    Description: OP-COM USB V2
    FTDI USB Serial: FTUB2223
    FTDI-ChipID ChipID: 0xA4C5A7D5
    FTDI-ChipID Location ID: 0x41
    O***M Serial-Number (calculated): 4GKMQ9VU
    O***M FW UPdate Code (calculated): 5PB18YCV
    Interface opened. Handle: 90770240
    Baudrate 500kBit/s
    Dataformat 8N1
    Flowcontrol NONE
    SetChars
    Timeout 5 seconds
    Set DTR and RTS Low = PIC Reset
    DTR low
    RTS low
    Wait 1 second for reset
    Set RTS High = PIC running
    RTS high
    Wait 1.5 second, so bootloader can start FW...
    RX Buffer clear... OK
    FW Versions- and Interface ID- request send.
    Timeout - is your PIC empty? No Firmware?
    *** Firmware Version: 7F.0
    Set RTS to LOW = PIC Reset
    RTS low
    Communication closed. Handle: 90770240
    Is there a possibility of repair?
    lkjubaking's Avatar
    Feb 2013
    Serbia
    SOLVED
    speedy100's Avatar
    Athens
    How did You solve it?
    Can You share please?
    Knowledge is to share... so if I have helped just press [Thank You + Rep.]...
    Aug 2008
    reprogram pic
    i think dumps on here or net somewhere
  5. The Following User Says Thank You to tango For This Useful Post:
    speedy100 (15th June, 2014)
    speedy100's Avatar
    Athens
    Hi tango,
    I have been playing all day trying to repair my OpCom.
    I have found the hex file etc. and I am using Willem ver. 5.0 programmer in serial mode.
    It reads, erases, writes code but does not write Data!
    Do I need to lift any pin of the board? or any other idea?
    Thank You for Your time!
    B.R
    Feb 2014
    i think reinstall and this problem will sloved
  8. The Following User Says Thank You to Tomthomasxx For This Useful Post:
    speedy100 (20th June, 2014)
  9. #7
    speedy100's Avatar
    Athens
    Quote Originally Posted by Tomthomasxx View Post
    Problem solved.
    It was the software version of my programmer... After updating it was a one minute job.
    It works fine again.
    Best Regards
  10. #8
    Usa
    Problem can solved only with reprogram firmware in version PCB v5 china clone (and older) with REAL MCU PIC18F458 inside.
    New version PCB v6 china clone have inside FAKE MCU PIC18F458, so if kill interface with wrong version software it is impossible to reprogram MCU with firmware.
  11. The Following User Says Thank You to tango5 For This Useful Post:
    speedy100 (11th July, 2014)
  12. #9
    speedy100's Avatar
    Athens
    Quote Originally Posted by tango5 View Post
    Thank You for Your reply tango5!
    My problem was my Whillem programmer. It was solved by updating the Whillem software.
    One problem I have encounter lately though with OPCOM 1.39 is In Opel Corsa D 1.2 gasoline (Z12XEP) 2008 model. OPCOM can not communicate with CAN Dash (IPC) and Airbag (SDM) modules. It shows that it tries to initialize communications and that is all.
    Communications and programming with other modules are working fine.
    Are there any special communications parameters to change in order to overcome this problem or any other idea?
    B.R.
