Results 1 to 5 of 5
    Junior Member nobody's Avatar
    Jun 2008
    Default Patch Walkthrough
    Hi, Anyone know of a ?walkthrough? for patching my brand new TM 6900 HD. I?ve had a go but no joy it could be me or maybe the patch I don?t know. Cheers Nobody
    Jun 2008
    Is there a FAQ available for the TM6900 combo
    Aug 2008
    Hi Nobody,
    I hope you've been able to patch it since you posted. If not, I have one and have patched using both the 'special' serial cable and also via USB memory stick. I'd recommend the USB approach.
    Give me a shout if you need more details.
    Oct 2008
    Hi sorry for butting in but can you give me a walkthro on how to patch my TM5400Ci with a usb memory stick please ama complete newbie of 57 years but will need help to learn
    Retired Sat TV Addict
    .: JaCkPoT :.'s Avatar
    Aug 2008
    var/tuxbox/plugins
    I will make a usb sticky for patching at a later date.
    First download and extract files to your usb stick. Then put it in the receiver and goto the menu and select usb. Then goto software and select the file which you saved to your usb and press it and it should start to patch your receiver. Im not 100 percent sure as Ive only done it once on my uncles 6800. If it dont work then read my sticky and do it via pc.
    Read the Rules here; they apply to Everyone.
    ___________________
    In the good old days, I had
    DM800s HD
    Openbox S10
    TM500
    DM500s
    90cm FortecStar dish
    Technomate 2300 Motor
