Results 1 to 12 of 12
    Sep 2013
    Default HELP TO READ 1D69J WITH ORANGE 5
    I NEED READ EAM MERCEDES ML270 2003 MOTOROLLA 1D69J WITH ORANGE 5
    electrones's Avatar
    Feb 2012
    Around C.V
    Quote Originally Posted by petarcanev View Post
    HI m8
    With Xprog: http://www.digital-kaos.co.uk/forums...please-383124/
    Cheers
    Press "THANKS" button. just one click, CHEERS
  3. The Following User Says Thank You to electrones For This Useful Post:
    petarcanev (20th April, 2014)
    Sep 2013
    thanks electrones not have x-prog i have orange 5
    ttzag's Avatar
    Jun 2010
    digital-kaos
    remove it from PCB
    solder to adapter hc05x
    select MC68HC05X32
    press skip security if not success select MC68HC05X32 div5 then press skip security again then read
    Actions speak louder than words
  6. The Following 10 Users Say Thank You to ttzag For This Useful Post:
    AndyCZ (8th October, 2018), BusCan (16th December, 2021), csavargo2 (13th April, 2019), gomarota (15th February, 2017), immoneard (19th May, 2020), Mrce (12th May, 2019), mrgenrih (10th March, 2021), narkeleptk (26th October, 2017), neksus (29th August, 2020), petarcanev (20th April, 2014)
  7. #5
    Sep 2013
    thank you friend thank you......
  8. #6
    Sep 2015
    Botswana
    Quote Originally Posted by ttzag View Post
    remove it from PCB
    select MC68HC05X32
    a
    i have a similar problem was trying to read eis with 1d69j and it read first line and failed now its just reading fffffff please help
  9. #7
    Sep 2019
    Quote Originally Posted by LEORNARD NKATA View Post
    a
    did you get it fixed? i am about to read this tomorrow so want to know if you successfully read it. thank you in advance.
  10. #8
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Quote Originally Posted by remote doctor View Post
    orange 5 clone not work good with this mask(but can read rom & rom1 fine)..... xprog works better....... be very carefuller with this mcu, is very sensitive in heat....
  11. #9
    Aug 2009
    Hampshire
    i have original orange and omega, but i can only read the above mcu with omega, not ornage5.
  12. #10
    fred77's Avatar
    Jun 2019
    a
    sadly u may have wiped it. Genuine gr8 tool it's 100% ish safe but must do security 1st.
    feel for u mate i was told how to use tool by other forum . instructions terrible
    Maybe best do an ebay search n just replace whole ecu set to fix. Not too expensive to save reputation
    Naz mate i've always done these old mercs with orange by removing - but been sum 12 months i only get newer ones now.
    will call u my pal
    Solidarity with Ukraine
  13. #11
    Aug 2009
    Hampshire
    Ii may be something wrong with my gear, i have never managed to read that mcu with orange zif adapter or the board, but always managed with my omega. talk soon.
  14. #12
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Quote Originally Posted by nazz2 View Post
    as i told, my Orange 5 (clone) some times read that mcu and some not, i notice that if i don't have very good soldering the legs in adapter i get error... after a good solder it can read the eeprom(it may be random)
    , but not write it back.......
