external addons/repositories on the xbmc box
Results 1 to 3 of 3
    Nov 2008
    Default external addons/repositories on the xbmc box
    hi all ive got a mx xbmc set top box now is it possible to add downloaded addons / repositories via usb/sd card to a mx box.
    ive added the files (zipped) to sd card inserted into box and clicked on add files via ext storage but couldn't find the file found my music which is on the card but no zipped files , should I unzip file then load onto sd/usb and insert to box or am I doing something wrong.
    when I used to dable in the satellite recievers I used to ftp files but not sure if you can do this with these
    any info would be good
    many thanks
    Member etch's Avatar
    Sep 2010
    Pontypridd, South Wales
    Go here mate XBMC HUB FORUMS The guys there will help you and get your system up and running
    Oct 2018
    I am creating a simple application that will pop up an alert box , take an input from user and whenuser click ok it will operate on that input.So how can i do that ?
