if you know how to use a terminal then enter
sudo apt-get install p7zip unrar rar
then enter you password, the default GNOME archive manager can now handle rar's mate
hmm i was at this also last week and it wouldnt work on ubuntu 9.04 and its a new original disc, any other suggestions m8
ok im gettin this
home@desktop-linux:~$ sudo apt-get install p7zip unrar rar
[sudo] password for home:
Reading package lists... Done
Building dependency tree
Reading state information... Done
Package p7zip is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package p7zip has no installation candidate
so im guessin its not there
You won't need p7zip for rar files. Just unrar for uncompression, soshould do the job.Code:sudo aptitude install unrar
I'm not using Ubuntu, so it might be named slightly differently, butshould give you the actual package name.Code:aptitude search unrar
abit late i know but heres winrar for linux
To install, simply extract this archive to a place such as your desktop. Then download a Windows WinRAR installer such as wrar371.exe (although you should download the lastest version). Copy this .exe into the WinRAR Installers directory. Now open up a terminal window and change directory to the on that this ReadMe.txt is in and run 'WinRAR.sh' or depending on your version of Linux, you might just be able to double click on WinRAR.sh and it will start. Click the Install button and select the version of WinRAR you would like to install from the list and click the Install button. Hopefully a message will appear saying that it is now installed. Click the OK button and then click Run from the main menu. WinRAR will now start!
Deposit Files
use Synaptic Package Manager click find and write unrar, mark it and install
you've probably only got the cdrom repositories selected, open synaptic and select all the other sources in the repository.
Hello , how to install RAR (Archiver)
sudo apt-get install rar
sudo ln -fs /usr/bin/rar /usr/bin/unra
the best sw for me is unrar...
You can use ark under KDE with unrar.
jeff
You can also install wine+winrar if you like more winrar from windows.
