Results 1 to 8 of 8
    Apr 2014
    Default Golf 3 16V ABF 024AB
    Hello everybody,
    I am looking for WOT ignition map location for 024AB ecu from a Golf 3 ABF.
    Can you share just the WOT ignition map location only, because its urgent?
    Thank you!
    Above sea-level
    Does the ABF engine have a WOT switch? If not, it probably only has the partial throttle map upto 100%.
    Can you post the original file?
    Apr 2014
    I think it has a throttle pot.
    As far as i know digi 1 ecus g40/g60 do have a idle/wot switch, but they do not have a wot ignition map. They read direct from the main 16x16 ignition map.
    I think that those dig3.2 ecus have a both ignition and fuel maps
    Here is the ori:Golf 3 16v Siemens 5WP4 133 037 906 024 AB.rar
    Any tips?
    pandokrator's Avatar
    Oct 2008
    Eu.Gr
    some last G60 (passat) using TP sensor and Not only two switchings (open and close) for wot.
    from that dump you need search for extract Wot map from xdf file
    also,g40/g60 ecus (digifant 1) is bosch not siemens.
    bR
    Apr 2014
    I turned into 2D view, i have traced ignition and fuel at part throttle but i cant find the wot maps
    Wot ignition:9998777
    Any ideas please?
    Apr 2014
    Any ideas???
    Tefocm's Avatar
    Sep 2013
    Planet Earth...Take me to your leader.
    Hey guys, may I please have a tuned file for VW Golf MkIII GTI 2.0L 16v ABF, its using a Siemens Digifant 3.2 ECU 133 037 906 024 AE...Im not asking for crazy performance, just something that can make a standard motor stand out, something with no immo though. Please :-)
    Apr 2016
    croatia
    Default VW Golf MkIII GTI 2.0L 16V ABF
    greeting
    siemens 5wp4 133
    037 906 024 AB
    NM27c256QE
    still does not work
    can someone immo off
    thank you
  9. The Following User Says Thank You to sep382 For This Useful Post:
    Ixso88 (5th March, 2021)
