Page 10 of 25 FirstFirst ... 5678910111213141520 ... LastLast
Results 136 to 150 of 367
  1. #136
    Aug 2016
    EURO-KOLCHOZ
    Hallo, I have master 3.0 dci ecu 0 281 012 200 with eeprom fault df001, car not start, can somebody fix the file for me ? or working virgin solution with the possibility of injection coding.
    Thank You
  2. #137
    Dec 2018
    IMPORTANT NOTICE
    This fault may occur if the wiring is damaged.
    Follow the steps outlined in the "Checking the wiring" subsection of the "Introduction" section.
    This check allows you to determine the condition of the wiring harness of the engine compartment.
    if everything is checked and properly then this is ecu damage
  3. #138
    Aug 2016
    EURO-KOLCHOZ
    Quote Originally Posted by Catalizator View Post
    IMPORTANT NOTICE
    thank you for answer, I made an ecu clone and its the same, after I did virgin on the new ecu and the car starts but can not code the injectors...
  4. #139
    Hello everyone
    Renault Master 2 2009 O281013364 8200635663
    problem, loss of injector codes, AAAAAAA
    I need a virgin
    thank you
  5. #140
    rafal's Avatar
    UK - PL
    Quote Originally Posted by cavignac View Post
    Hello everyone
    I need a virgin
    thank you
    read again...................eeprom is empty
    need help
    now my goal is to buy xp-005
    who will help?
  6. The Following User Says Thank You to rafal For This Useful Post:
    galaxy0634 (22nd April, 2019)
  7. #141
    That's all I have, if you can help me
    I have full back
    thank you
  8. #142
    Dec 2018
    open eeprom to hex, and see that it is clean, nothing is recorded.
  9. The Following User Says Thank You to Catalizator For This Useful Post:
    rafal (22nd April, 2019)
  10. #143
    that's why I could not telecode the wine + injector code
    if you can help me with the telecoding procedure I thank you so much
  11. #144
    rafal's Avatar
    UK - PL
    Try read ecu again.....if eeprom will still empty than you will need find full back up of ecu.
    Lost injectors....What have you done?
    need help
    who will help?
  12. #145
    I read two foix, I can not read it a third foix, by which I wrote the eeprom with another file, the vehicle starts and rolls well, the problem is the indicator light (spring) , excuse me I do not have the photo, and I send you the full
    thank you
  13. #146
    Dec 2015
    hallo! waldi i need you help. pease virgin 0281013018
  14. #147
    Dec 2018
    virgine
    pass pm
  15. The Following User Says Thank You to Catalizator For This Useful Post:
    Kharkov (25th April, 2019)
  16. #148
    Dec 2015
    CATALIZATOR - VERY BIG THANKS!!!!
  17. #149
    Sep 2012
    Prague
    Hi, can you please make my dump virgin. I have Vivaro 2.0 CDTI 84Kw ECU 0281014648 and eeprom is probably corrupted. I have present fault P0611 and can not program injectors (all AAAAAAA) and can not reset service.
    Thanks a lot
  18. #150
    Bllinda's Avatar
    Baltic
    If you don't help others like I can help you ....
    Quote Originally Posted by mzabka View Post
    Thanks a lot
    today
    A topic that interests me
  19. The Following User Says Thank You to Bllinda For This Useful Post:
    Catalizator (6th May, 2019)
