where.can.i.find.instructions? thanks
Try this file.
beli123 (21st August, 2019)
hi waldi1979
plz need you help i have problem eeprom edc16c36 renault trafic corrupted cant coding injector and also immo code not received now car not start
can you help me with good virgin file i tried severalsoftware but always DF107 eeprom memory error
thx
VAG Bcm2,pcr2.1,edc17,med17,MED9.1.1 immo clone & data transfert
PSA sid208 immo clone,synchro to bsi
RB4,RB8 DEF FIX
ODIS-S and E full install via remote
Try .... ....
A topic that interests me
toutougsmserver (27th September, 2019)
Thank you my friend for file but is not working
Still DF107 EEPROM memory error
Cant enter injector code and car not start
Any working solution i ll be appreciat
RB4,RB8 DEF FIX
Thx Bllinda Your file is working was only problem with writing bdm
Your job is excellent
Best regards
RB4,RB8 DEF FIX
I have here a Opel Vivaro 2,5 TDCI 84kW (0281013363 8200635663) with Error P0089-0D and P0089-09 after somone has tryed to make DPF off and on again. He flashed only via OBD. Car runs in idle, but by pushing gas - the car goes off. Injectors ar learned ok. Pump , Sensor, high pressure regulator and wiring are ok. wanted pressure in idle is nearly 400 bar - actual value is nearly 1600 bar. I think here is some broken in the eeprom , pump characteristic.
here my readed BDM. can someone fix this?
Kind regards
Hello, i have problem with P062F in Renault Master 2.5 DCI. Anyone can repair that ?
You haven't learned how to press a button yet?
https:/ /www.digital-kaos.co.uk/forums/showthread.php/779630-Renault-Master-2-5-DCI-P062F?p=3695270&viewfull=1#post3695270
Which button ?
I write injector by KTS but still have problem..
Wysłane z mojego EVA-L09 przy użyciu Tapatalka
try .... c.a.n.clip
Hello Everyone!
I have messed up my file and unable to read eeprom now from old ECU.
I have ordered an used ECU but i will have problem with immobilizer i think?
I was thinking about making the old corrupt ecu virgin.
Partnumber: 0 281 013 364
Chassinumber: VF1JLBJB69Y312495
Renault Trafic II 2.5 dCi 145
146bhp/107kw
Volume cm3 2464 cc
Engine code: G9U 630
Can anyone help me with this please?
Cześć. może ktoś pomóc dziewice dla Renault Master 2 2.5 100 KM
Hi. can anyone help virgins for Renault Master 2 2.5 100 hp
DudaTK (21st October, 2019)
