Hello members !
With your support I will need also to make virgin this dump !
Thank you !
U
Hello members !
Thank you !
U
virgin eeprom
pass on pm
unu (12th February, 2019)
I need virgin for Renault trafic ecu.
Ecu is 0281 013 364.
Thanx advance
virgin damp. pass pm
tomo776 (20th February, 2019)
please virgin eeprom
virgin damp for giovani
giovani (22nd February, 2019)
Hi all
please virgin eeprom opel viavaro edc16c36
Here is your opel viavaro edc16c36 virgin.rar
I have problems with ECU 0281013363 of renault master ph3 motor g9u 2.5
i can´t program injectors even with clip or abrites (internal error)
if its possible please look to the eprom file read on bench to see if the problem is this .
I have the code if is necessary to make virgin
The file looks ok. Try this virgin file, pass in PM.
aureltek (27th March, 2019)
Good afternoon. I have a renault trafic with a problem in programming injectors. Can someone help me?
referência ecu 0281014648 8200666516
When I have problem with coding injectors I make reprogram with clip and then coding injectors it’s ok.
You can try this for me every time works.
doctorelectrical (26th March, 2019), Louislesinge (29th March, 2019)
tanks I already solve the problem . i program with x431.
Enviado do meu Mi A2 Lite através do Tapatalk
The file that i received resolved the error because of the mix between opel ecu(engine)to UCH renault.Put all injector code AAAAAAA and can´t be programed even with original clip diag.
Thank you for support
