Results 1 to 8 of 8
    spain
    Default error long coding abs audi a3 2009
    hello my friend i need to coding abs for audi a3 but i can't
    can someone help me please!
    spain
    any personne have a solution!!!!!
    spain
    Envoy? de mon GT-I9100 en utilisant Tapatalk
    smokey08's Avatar
    Essex, UK
    Where did the coding you are trying to enter come from? These are coded online so you will find it very difficult to find the correct coding.
    spain
    The problem is when i virgen the immodata from instrument with avdi (abritus) i calcule the coding with the abritus software !!
    smokey08's Avatar
    Essex, UK
    Try adding 00 on the end of it then test drive the car before turning the ignition off.
  7. The Following User Says Thank You to smokey08 For This Useful Post:
    antonypaul (10th May, 2014)
    spain
    i don't understand you my friend !
    add one byte more to the end of long coding thart vcds calculate. new units have one byte more in the string. add 00 to the end of code and try
    You need the PR codes from production for calculate the right coding, dificult but posible
    good luck
  10. The Following 2 Users Say Thank You to audiomeca For This Useful Post:
    antonypaul (10th May, 2014), garagetech (8th June, 2014)
