Results 1 to 2 of 2
    Member Squadr33's Avatar
    Aug 2013
    The Netherlands
    32
    Downloads
    563
    Uploads
    7
    Default The All in one Android kit
    Very useful all in one kit for those that don't want the hassle of working with ADB terminal, but want the full flexibility of ADB protocol.
    Features:
    1. Fast Data Transfer Using adb ( Instead Of SD Card Mounting )
    2. Tweaks for Android
    3. Build Prop Editor
    4. Android APK Manager
    Requirements:
    1. Android Device Connected To PC in Debugging Mode Enabled
    2. USB Drivers Should Be Installed
    User Manual :
    1. Fast Data Transfer Using adb ( Instead Of SD Card Mounting ):
    We used to transfer our data in mobile phone by connecting SD Card to pc but As per my experience it takes much time to connect for bulky SD Cards . So By using this feature You can pull data from device or push data from device
    Pulling Data From Phone :
    Just select the folder of SD card from which you want to pull data Viz. download , music ,videos I Made ready made option for that You can even set custom folder by giving path in that field like : /sdcard/Documents/
    Pushing Data To phone:
    In case you want to transfer a file to phone Browse that file and select the destination folder of your SD Card viz. download , music ,video or even custom path
    2. Tweaks :
    Most android users love android tweaks I made some tweaks for android like Unlock Pattern And Unlock Pin/Password On A Single Click ( *ROOT REQUIRED* ) . More Tweaks will be adding soon as per suggestions and requests
    3. Build Prop Editor :
    You can modify build properties directly using this application . ( * ROOT REQUIRED* ). This is risky part So Carefully modify build properties.
    4. APK Manager:
    Many people takes backup of their android apk apps. So when you havebackup and want to install to phone directly , use this feature. Browse the apk file and click on install Apk wait for progress bar to complete installation . & Yap.. App is installed.
    Download Toolkit: Zippyshare.com - Android All In One Toolkit.zip
    " You canít be a true petrolhead until youíve owned an Alfa Romeo " - Jeremy Clarkson
    Oct 2018
    Downloads
    Uploads
    Does the iconifyStack message get sent when going to the background on Android?
