Change egr to new or read file ECU and post.. egr off posible....
Hi, a friend of mine has a problem with the egr of his ibiza.
VCDS showed error code P0407 Potenciometer- signal too low.
Does somebody knows if I delete egr with swiftec solution the problem will be solved?
Or it does need a new egr cooler?
I ask this because he lives a couple of hours away and don't want that he comes for nothing.
Thanks in advance
Do not forget to THANKS !
SWIFTECH FULL
ECM Titanium FULL
KESS V3
AUTOTUNERS
B-FLASH
WINOLS
TOPDONE
AUTEL
FILE SERVISE .. web under construction
I can do egr off but i want to know if it will solve the problem.
How you do egr of in this ecu ?!
Br
My work is my life ART TECH GARAGE
will work read and post file.
if egr is elettronic problem you need to change it.
i do egr off and dtc off but if you delet connector the car go recovery.
ALL TUNING.
THE BEST OR NOTHING. THANKS + REPUTATION .
The egr works ok during a certain time.
Specified and actual value are almost the same all time.
But after a few minutes when the car is cold it goes into limp mode with that error code p0470 potentiometer- signal to low.
I will try to read it in these days and post the file.
Thanks for your help
If the problem is the electric engine ( doesnt work ) that moves the gears, the only solution is a new egr?
read and post file.
hi i have same problem with P0407 error
some one can help me?
this is the seat orig file seat ibiza ori.rar
